Question about Lexmark X6570 InkJet Printer
Copy double sided
I can not copy a two sided plain printer resets when i am finish the scanning
    Problem Solver:
  • 9 Answers
You should check the settings in the menu for duplex, there are several choices depending on what you are trying to do.
Posted on Oct 10, 2008
How to reset kyocera km 6030 Double sided copy mode. When i want to copy double sided page then i will see in screen... ""Reset All Originals in Document Processor ""
I think the message is "Reseat All Originals in Document Processor". This message apears when there was a misfeed or something like that. It means that you must put back all the documents, to be scanned again. Clean the paper feed/pickup rollers with a cloth dampned in alcohol.
Jan 21, 2015 | Kyocera Office Equipment & Supplies
How to put C460FW Samsung printer in "tech Mode"
(From ready to copy/Just finished warming up from power off)
Press the following buttons in order
Menu, Back, Left arrow, Right arrow, OK, Stop/Clear, Menu
Sep 01, 2014 | Samsung Xpress SL-C460FW Laser...
Two sided copies
that machine does not have an automatic duplexing capability
what you have to do to print both sides of the paper is in the print selection highlight print pages 1,3,5 etc and when finished turn the pages upside down and in backwards , the print pages 2,4,6,8
in the pages selection -print odd pages then when done print even numbers
Jun 17, 2017 | HP Officejet 6200 All-In-One InkJet...
How to scan double sided documents
With a home scanner you can only scan one side at a time. Some printer copiers are capable of double sided copies but the machines are big and bulky because they have to run the paper on one side then flip it over and scan the other side. These type machines are for office use. What kind of scanner are you trying to use? Is it the Lexmark as listed, if it is then it is not capable of scanning double sided documents. they must be scanned one page at a time.
Oct 01, 2011 | Lexmark Prestige Pro 805 Color All-in-One...
Can not get printer to copy 2 sudes of a paper
Try to unplug and replug the printer into the power source to reset it. When the printer turns on, try to copy 2-sided again. Refer to the Lexmark 7500 Series User's Guide for the step-by-step instructions on how to copy on both sides of the paper.
  • Use only plain paper in Letter or A4-size. Do not make duplex copies on envelopes, card stock, or photo paper.
  • You cannot print duplex through the PictBridge port.
May 22, 2011 | Lexmark X7550 InkJet Printer
We have 2 Canon ImageRunner 3320N copiers, but they are behaving differently when they are being used as a scanner. On one copier, when scanning a double sided paper it will automatically scan each side....
it is in the copier settings. one is actually set up to automaticly do doublesided copies as a default. while the other one is only set up to do singlesided copies
first while on the main copy screen change the setting how you want the copier setup ..... double sided printing, black and white, or how ever you want your defaults to be set up
then you will need to goto the additional functions button and under copy settings you will need scroll down to the second page.
there you will want to hit the standard setting button then click the store button, then click yes... now it will default to the double sided copies.....
hopefully this will fix the problem if not get back to me
Jun 18, 2010 | Canon ImageRunner 3320N Copier
Cannot print double sided
On the machine when a 2 sided document is inserted in the document handler, select the 2x2 button on the console. Press the start button and the machine will feed the document in, and do a reverse of the document for the second scan. In the paper feeder, the machine feeds the paper in and reversed the copy back into the machine, flips the copy then feeds the copy back for the second side to be copied.
If you do not have a m20i, the lower model numbers will not do two sided copies.
Aug 14, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Double sided copying
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
HP 2710 Printer
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
May 30, 2008 | HP Photosmart 2710 All-In-One InkJet...
Lexmark X6570 InkJet Printer Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
