Question about Clarion DRB2475
Removal of Clarion DRB2475
I need to remove the Clarion DRB2475 in-dash radio from my car. Could someone post the installation/removal instructions for that radio?Thanks
  • Anonymous Nov 19, 2008
    jai le meme probleme que toi peut tu me dire si tu as reussi et comment sev.....merci d'avance
  • laraque Jan 05, 2009
    please help! don't know how to remove it here either!
shadow5599
  • 51 Answers
SOURCE: Pioneer Super Tuner 3 Removal
If it's been installed with the original DIN mount, there are 2 small flat clips that slide in a small slot on each side of the radio. The 2 pieces of metal are pushed in to release the clips holding the radio in the bracket. Then the radio pulls out
Those clips come with the Pioneer stereo but should be available from a place that sells/installs car audio
Posted on Oct 16, 2007
thesoundman
  • 41 Answers
SOURCE: manual
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
mixmaster
  • 626 Answers
SOURCE: Desperate Need of owner's manual :(
Found it on the Clarion Support Page;
http://clarion.com/us/en/MungoBlobs/82/1021/DRB3475(Manual).pdf
Best of Luck.
SOURCE: setting the digital clock
setting the clock
1) Press and hold in the BAND button 0J then
press the DISP button lID to toggle the display
to the clock mode.
2) Press and hold in the BAND button 0J then
press and hold in the DISP button lID for at
least 2 seconds.
3) Select left or right to adjusf the time using the
a-selector.
.AdJustlng minutes
Each time you select right "' using the aselector
~, the minutes increment up by one
digit (0 to 59).
.Adjusting hours
Each time you select left <.. using the aselector
~ ,the hours increment up by one
digit (1 to 12).
*The clock only dispiays time in a 12-hour formal.
There is no way to toggle the clock to a 24-hourfonnal.
4) Press the Band button [1] tb set the clock
into memory. This aiso resels the seconds
counler to zero.
Note:
• The clock can only be
set by turning power on to !tie
unil andswitching /0 the clock display mode. You can·
no/ set the clock when it is displayed with only the
ignition on. If
you drain or remove the car's battery.
the clock must be reset. While setting the clock, if
ano#lerbutton or operation
is selected. the clock sel
mode is cance/ea.
Posted on Nov 21, 2007
SOURCE: connecting clarion radio cassette arb1170e
error 6
Posted on Aug 01, 2008
Clarion nz409 how to remove properly from dash .
Yes you will need the keys that came with the radio. If you cant find them you will need to go somewhere like radio shack or somewhere else that installs car stereos and have them remove it for you.
Mar 25, 2012 | Clarion Car Audio & Video
I have just got a car with a clarion dx418r radio in, its a bit hit and miss as to working and i am trying to remove it, how do i do it?
Removal instructions depend on the make+model of the radio
Find your free removal instructions from this list on this website
www.fitaudio.com
Jan 29, 2011 | Car Audio & Video
How to remove a Clarion AB213R radio-Cassette ?
It depends on the type of Clarion Radio.
There are 2 types of Clarion Keys depending on the size of the removal slots in your radio  ...the older , larger version or the later slim version.
See the difference here
http://www.incaripod.com/Brand/Radio_Removal_Tools
Available on Ebay , local car radio store etc
Jan 22, 2010 | Clarion Car Audio & Video
Clarion DRB2475 mutes when I turn up the volume
Sound like one of your car speakers is faulty, try using the fader and see if it still happens when all sound is to the front or rear and try left and right.
Nov 16, 2009 | Clarion DRB2475
1987 Volkswagen Golf - tach light out, no power to radio/CD player
could be just a blown bulb for the tachometer.check the wiring behind the radio .you may have to get special tools to remove the radio in any car parts/stereo store
Oct 15, 2008 | 1987 Volkswagen Golf
Car radio install
There should be an actual wire harness for radio back in there somewhere, maybe tied up or bundled up, just have to find it, then buy from stereo or automotive supply place, an adapter that will go from factory plug to your other stereo, and it will make installation much, much easier.
Aug 17, 2008 | 2008 Chevrolet Express
Automatic Antenna
sounds like a new aerial is needed, if noone has messed with the wiring...
get someone to turn on the radio while you listen near the aerial...
if it sounds like it is making an effort to work then it could be the nylon runner...
if it doesnt make a sound check the power & earth connections at both ends, behind the stereo & at the antenna.
some have 3 wires power,earth & switched.
some only a switched & earth.
Dec 27, 2007 | Clarion DRB2475
Manual
Jun 20, 2007 | Clarion DRB2475
Car Audio & Video Logo
333 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
