Signal processing board removal
How do I remove the SIgnal processor A board. This one and the D board (deflection) board are attached together through white D connectors. Unable to figure out how to disconnect the conenctors. Any help is appreciated.
Panasonic PT47WX52F
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT47WX52F
those are bridge connectors they stay attached to the A board and release from the D board. Just slide a small screw driver under the bridge on the D board side and gently lift up they will pop right off.
Posted on Sep 11, 2008
WS-65819 Shuts off
Yes, remove front speaker grill (pulls off) and inspection plate behind it.
There are 3 large circuit boards as you look from the front---signal to the right, power to the left and Deflection (vertical and Horizontal) in the middle.
What you want to look for is on the middle board any sign of GLYCOL which sometimes leaks from the picture tubes above it.
It is a clear liquid and even tiny amounts can short or stop the board from working; most damage should be in first 3 inches from front of the board----if you find any DO NOT TOUCH IT as it is toxic.
Glycol damage is not uncommon and the first thing you want to look for.
Jan 26, 2012 | Mitsubishi WS-65819 TV
Digital surround mode doesn't work,just analog dvd 6ch.input
Failure of the sound processor. All you can do is to remove the cover, clean the insides, check the cables to make sure they are still firmly plugged in and then measure the 5 volts power line from the source. If all appears OK the the processor has died - a replacement board is mandatory. It will be cheaper to buy a new receiver .
Sep 29, 2011 | Technics SA-DX850 Receiver
RCA D52W20 - I have sound but a black screen. checked all connections, not even snow. How do I find and check the signal board? Is this replaceable? Is there a diagram available?
If you have sound but no picture its a deflection issue and not the small signal board, the deflection board is the cause. Try resoldering the flyback transformer often that will take care of the issue.
Sep 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Left rear turn signal light replacment
To replace the left rear turn signal light, please follow the steps below:
  1. Open the rear hatch of your van.
  2. There are two black button like protrusions behind the hatch next to the turn signal lamp.
  3. Pry these out and remove lens.
  4. Replace bulb.
  5. Then reverse the process th reassemble the hatch back together.
Hope this helped. Thank You for using FixYa!!!
Jan 12, 2011 | 2004 Chrysler Pacifica
My Mother Board Is **acer sf2 661fx rev 1.1**. Now I Have A Problem, Please Solve This.......... No Signal To Monitor, But Mother Board Is Working. After That I Tried To Solve The Problem By Following...
haii all.....
i facing problem on mb acer sf2 661fx rev 1.1 no power to cd rom and hdd...also monitor not shown anything... cpu fan and casing fan only working..any idea pls..
Aug 03, 2010 | Acer (ACERMOTHERBOARD)
GA-8IG mainboard. power comes on as soon as plugged in all fans work but no lights. No sound no signal to monitor. tried new power supply it wouldn't power on at all.
check for any physical shot in the board....
it ma happen only if the board turns faulty
remove all the attachments on the board sucha as ... processor ...ram... and any add on cards and then check .... if ok...
install the processor and then check........
you should get a long beep sounds
Sep 28, 2009 | Gigabyte GA-8IG Motherboard
Front Turn Signal Lamp Replacement
Yes, I would remove the entire headlamp assembly. This is easier than you think. Unscrew the large black plastic nuts (you should be able to use your fingers, if not then use a pair of pliers) which are on top of the headlamp lens (2) and the turn signal lens (1). The turn signal lens also has a metal screw-in stud attached to it. The headlamp lens lifts straight up and is attached to the turn signal lens by a clip at the bottom. The turn signal lens is attached by a clip to the inside fender. You will need to pull / **** the turn signal lens straight towards you to get the clip to disengage. Once you remove both lamps you will see how they fit together to place them back in position. It takes approx 15 minutes to replace a bulb, since the alignment during re-assembly is a bit tricky.
Dec 31, 2008 | 2003 Oldsmobile Silhouette
Panasonic PT47WX52F
Sep 11, 2008 | Televison & Video
Bow in tv
Hello trumpold,
The bad new is the resistor is bad. If it is reading 2 ohms its bad because the rated value is .29 ohms and 5% tolerance. I would venture to say that the convergence amplifiers have gone bad. due to excessive current. Since the deflection and convergence boards work together they might both be defective. I would first suggest that you take the TV to a qualified TV repair shop, to perform the repair, but if you what to do this yourself you will need the following items:
1) Schematic of the TV in question (www.servicemanuals.net or www.manualsparadise.com
2) Signal Generator or use the on-board Signal Generator (look in schematic for usage.
3) Multimeter (for resistance, and voltage readings)
4) soldering iron, solder, and de-soldering tools (solder wick, and de-soldering pump)
With these items you should be able to determine the components you need to change, and remember follow the instructions in the schematic exactly as to board removal.
Before reinstalling the convergence board after changing out the convergence amps and ALL (I maen ALL) biasing resistors, check for solder bridges and shorts, removing them with the solderwick.
I hope this helps
Thank you,
Shuttle83
May 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
