Question about Car Audio & Video
Removal of radio--91 caddy
I have the trim plate off, and have removed the two screws that were at the top of the radio. There appear to be two clips at the top that also hold it in, am I correct or how do I proceed from here?
TAKE DASH OUT OF WV CADDY
Posted on Dec 16, 2008
I WOULD TRY TO LOOK UNDER THE DASH TO SEE IF THERE IS A BRACKET ATTACHED TO HELP SUPPORT THE WEIGHT OF THE RADIO IT MIGHT HAVE TO BE LOOSENED OR MIGHT HAVE TO TAKE SCREW ALL THE WAY OUT YES THOSE CLIPS MIGHT BE HOLDING IT BUT MAKE SURE THEY ARE NOT HOLDING THE DASH DOWN BEFORE YOU TRY TO REMOVE THEM IF THIS IS HELPFULL PLEASE GIVE ME A GREAT RATING THANKS PJDADJ
Posted on Sep 07, 2008
I'm having problem taking the trim off the dash that goes over the instrumental panel behind the steering wheel
Remove the steering column upper trim cover to accesse the lower screws to the instrument panel cluster trim plate.
Remove the upper screws from the instrument panel cluster trim plate. Remove the instrument panel cluster trim plate from the instrument panel.
Aug 23, 2015 | 2000 Pontiac Grand Am SE
Instructions how to step by step replace ignition lock cylindor for an 1999 oldsmobile intrigue
1999 Oldsmobile Intrigue
IGNITION SWITCH AND LOCK CYLINDER REPLACEMENT
1. Disconnect battery
2. Disable Supplemental Restraint System (Airbags)
3. Remove traction control switch from rear of center console plate
4. Open console lid and remove screws at front of console
5. Pull console plate up to release clips and slide over shifter
6. Pull rearward to release clips retaining instrument panel accessory trim plate to instrument panel
7. Remove screws attaching radio to instrument panel
8. Disconnect electrical connectors and remove radio
9. Take down instrument panel hush panels and disconnect courtesy lights. Remove hush panels
10. Remove knee bolster and knee bolster bracket from driver's side below steering column
11. Remove screws from IPC trim plate
12. Pull out instrument panel cluster trim plate to release from retainers
13. Remove trip odometer and reset switch from IPC trim plate
14. Remove IPC trim plate
15. Remove screws from IPC and pull IPC out
16. Disconnect electrical connectors from IPC and remove IPC from the instrument panel
17. Disconnect ignition switch connectors
18. Turn ignition switch to the ACC position and remove park lock cable from ignition switch
19. Turn ignition switch to ON position
20. Depress and hold locking tab on right side of ignition switch with a small, flat-bladed screwdriver and pull ignition lock cylinder from ignition switch
21. Remove ignition switch bezel from ignition lock cylinder
22. Remove screws attaching ignition switch to bracket
23. Remove ignition switch through the IPC opening
24. To install, reverse procedure
Apr 04, 2011 | 1999 Oldsmobile Intrigue
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
Removal
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
Installation
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
Removal
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
Installation
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
Back
Removal
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Installation
    Liftgate
2010&c18=modelyear&c35=wsm%2ctrim%20panel%2c%20door%2csww%2c01-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1998 Ford Windstar
My 2002 Pontiac Grand Am's heater/ air cond fan switch is bad. how do i replace it
If I've understood u correctly follow the wire from the fan to the switch which is usually mounted on or by the thermostat housing. Remove the coolant cap to releive the pressure. Remove the plug from the switch & Use a wrench to remove it but have the replacement one ready to install (thread sealer etc) & prepare for some coolant loss. put in the new one & tighten it snug but not over tighten. Plug it back in & u should be good to go
Jan 10, 2011 | 2002 Pontiac Grand Am
I needed to replace climate control unit on1997 Grand Am GT. Concerned with how to remove the cluster face panel w/o breaking it.
Let me know if this helps out.
Heater & Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the screws securing the cluster trim plate to the instrument panel.
  3. Tilt the top of the cluster trim plate downward releasing the clips that mount the bottom of the trim plate to the dash. Remove the trim plate.
  4. Remove the screws attaching the accessory trim center plate to the dash.
  5. Tilt the top of accessory trim plate downward releasing the clips that mount the bottom of the plate to the instrument panel. Remove the plate.
  6. Remove the screws attaching the control assembly to the dash.
  7. Remove the control assembly from the dash.
  8. Disconnect the control assembly electrical connectors.
  9. Remove the control assembly.
To install:
  1. Install the control assembly.
  2. Connect the control assembly electrical connectors.
  3. Install the control assembly attaching screws.
  4. Push the mounting clips into place and roll the top of the accessory trim plate upward into position.
  5. Install the screws attaching the accessory trim plate to the dash.
  6. Push the mounting clips into place and roll the top of the cluster trim plate upward into position.
  7. Install the screws attaching the cluster trim plate to the instrument panel.
  8. Connect the negative battery cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 40; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Jan 23, 2011 | Pontiac Grand Am Cars & Trucks
1990 corvette bose gold series stereo malfunction. How to remove to send to Bose for repair.Dont want to damage dash besels.
The trim is held in by sprung clips. Pry gently at the edge/corner with a small screwdriver until you can get your fingers behind it. Pull straight out. Here are instructions from autozone.com:
REMOVAL & INSTALLATION
Radio Control Assembly
  1. Disconenct the negative battery cable.
  2. Remvoe the shift lever knob.
  3. Remove the console trim plate.
  4. Remvoe the center air duct.
  5. Remove the instrument panel accessory trim plate.
  6. Unfasten the upper right corner console right hand trim pad-to-carrier screw.
  1. Unfasten the bolts/screws securing the radio control assembly. Pull the radio partially for access to the electrical connectors, then unplug the connectors and remove the radio control assembly from the vehicle.
Fig. Fig. 1: Exploded view of the radio control assembly
  1. Installation is the reverse of the removal procedure.
Oct 23, 2010 | 1990 Chevrolet Corvette
How do i take the radio out of my 98 xk8
Hi
1. Remove the black trim panel holding the cruise control and sport mode buttons from around the shifter. There are 4 clips holding the panel on: upper left, lower left upper right and lower right. Be careful, they break easily. Remove the wires from the buttons.
2. There are two brackets holding the wood panel down, one on each side of the shifter. Remove the two screws holding down each bracket. Be sure you note the orientation of the brackets - it will make reinstallation easier. Lift off the wood trim panel.
3. Under the wood trim you just removed, there are four bolts fastening the console to the car. Remove them.
4. Open the console lid. Remove the two screws fastening the latch strike plate. Again, make note of the positioning of the latch plate for reinstallation
5. Remove any other screws retaining the console compartment. Lift out the compartment liner. Close the console lid.
6. At the rear of the console is a trim cover. It is held by two tension clips. Just pull it off.
7. There are two bolts under the rear trim cover - remove them.
8. Remove the console.
9. Remove the screws holding the radio in the dashboard and pull the radio forward.
10. Remove the antenna wire and wiring harness connectors from the back of the radio.
11. Unbolt the ground wire from the back of the radio.
Reinstall in reverse order.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 31, 2010 | 1997 Jaguar XK8
How to remove the car stereo from 2007 Chevy Colorado
This is not hard but tricky because the trim plate around the radio has clips that hold the trim plate very tight.Use a plastic type flat tool or flat screw driver wraped with tape or a shop rag to avoid damage to the plastic trim and pry the trim panel around the radio loose. remove all elec connectors.Then remove the screws that hold the radio in place and remove all elec connectors.
Jan 30, 2010 | 2007 Chevrolet Colorado (Extended Cab) New...
How to remove the care stereo
Carefully remove the trim plate around radio, (clips into dash)
Remove screws and pull out radio
Disconnect radio connectors on rear of unit and antenna cable
Reverse procedure to install...
Mar 26, 2009 | 2001 Daewoo Lanos
Radio reciever ....cant get it out
First remove the selector trim panel for the Auto tranny or gear shift and boot trim panel for a manual tranny. remove the cigarette lighter assembly and disconnect the connector. remove the 2 radio mounting screws. You need the insert two radio removal tools T87p-19061 or equivalent into the face plate holes until you feel the tension of the holding clips. If this is the first tome removing the radio, the flashing of the bezel facing has to be broke. This may require extra force. flex outward on both sides of the radio simutaneously and pull the radio out using the tools as handles. Then dissconnect the electrical connectors. Hope this helps.
Oct 04, 2008 | 1991 Ford Probe
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
