Question about Kitchen Ranges
Stove doesn't get power
I plug it in and nothing happens. Is there a reset?
  • 70 Answers
Make sure you always cheak the clock to make sure it is on manual and not automatic because that will stop the oven from going but not the stove top if the whole thing is not going try to look behind or under the controls because there is usually some fuses there and they do tend to pop :)
Posted on Sep 07, 2008
Stove top and oven doesn't work.
If it is an electric stove it may have tripped one side of the 230 line. Check the house cuircuit breaker panel and find the stove circuit breaker. It will be tied together by a bar or clip. Shut off both breakers completly and reset them back completely. If it is a power problem this should reset the stove.
Dec 01, 2012 | Kitchen Ranges
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
Electric stove not working
If the oven burner doesn't light and it has an electric igniter, make sure that the range is plugged in and that there is power from the electrical service panel
God bless you
Oct 03, 2012 | Stoves Kitchen Ranges
Printer not switching on
unplug printer for a minute and plug it back in,this might reset it?if that doesn't work if theres an red X on the panel,hit that and maybe it will clear it?good luck:)
Jul 10, 2012 | Dell A920 InkJet Printer
When I plug in my pro form 370e crosswalk it doesn't turn on nothing happens
1) test the outlet wall, reset the c.breaker from your house, or tes the fuse if are blown.
if the problem NOT result and is o.k the c.breaker
2) test the power cord, for open
3) Eliminate any extension cord
4) test the main switch for open
5) reset the switch attached to the main switch.
6) tight any wires loose
7) reset the c. breaker or replace the fuse blown see the block.
God bless you
Jul 02, 2012 | Exercise & Fitness
Power was disrupted and stove needs resetting
Try turning the power off to the oven totally and leaving it for a few mins, then turn it back on. If this doesn't work you may have to have a new clock/timer. espares used to have them. If you don't see it listed, send in a request.
Jul 29, 2011 | Stoves 720EF Electric Double Oven
I can't reset my nokia e66. I even tried hard reset *#7370# but nothings happen. Is any other way to solve this?
I can't hard reset E66 with *+3+Green+power. The flash works then E66 keeps silently( Doesn't turn on). Pls help to solve. Tks
Sep 07, 2010 | Nokia E66 Smartphone
Stove power is out
Turn off the power.
Remove the rear panel on the range.
Repair the broken wire at the wiring terminal.
Install a wiring strain clamp at the terminal block to prevent this from happening again.
Mar 25, 2009 | Electrolux Kitchen Ranges
GE JCB909 Range - Blank display
suspect wrongly wired from new
Jun 25, 2008 | GE Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
