Just bought epson stylus cx8400 series, all in one. errorM69-cannot recognize ink cartridges ?
  • 2 more comments
  • Anonymous Feb 17, 2009
    Just got the cx9400 from epson direct. same problem.
  • Myrel Cairns Mar 18, 2009
    Printer will not recognize the new ink cartridges. Keeps coming up to"replace in cartridges. I have pressed onthem and they seemed to click when I put them in.
  • Anonymous Mar 31, 2009
    Same problem. Getting really irritated with this stupid brand.
  • Anonymous Apr 14, 2009
    I have the same problem with my Epson Stylus TX700W. The cartridges are brand new but not the Epson brand. Is this something Epson has done on purpose to force us to buy only their brand of cartridges?????
The cartridge (magenta-69) with the new unit was dried out !!
I purchased a new one and everything works fine !
Not impressed !
Posted on Sep 08, 2008
Epson Stylus NX 125/127 Series Both power light and ink light flashing not recognizing two cartiages
Power light flashing : processing. Ink light flashing : not recognizing cartridge. Replace the cartridges.
Feb 17, 2013 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus cx8400 will not print black, how do I fix
From the Epson web site:
Q:
Can the printer still print if an ink cartridge is expended or not installed? A: No. The printer will not operate if any cartridge is expended or removed. It's best to always have extra cartridges on hand.
I do this for fun not $$$.
Jim
Oct 16, 2011 | Epson Stylus CX8400 Series
How do I remove the black ink cartridge to put in a new one?
1 Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you're replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you'll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Nov 24, 2010 | Epson CX8400 All-In-One InkJet Printer
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
How do I change the ink cartridges
1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner.
Warning:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you’ll waste ink.
If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX8400 Series with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
got this from the Epson Site
Jul 29, 2009 | Epson Stylus CX4800 All-In-One InkJet...
CX8400 not recognizing new cartridges
I had a problem with one of my Epson ink cartriges and called the company and they replaced it for free. Also many companies that sell knock off ink cartridges now have fixed the problem and now they are recognized by the printer.
Mar 18, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Mar 05, 2009 | Epson Stylus R265 InkJet Photo Printer
Ink
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
Nov 10, 2008 | Epson CX8400 All-In-One InkJet Printer
Expson CX8400 All-in-one printer
Jul 11, 2008 | Epson CX8400 All-In-One InkJet Printer
New out of box!!
If you already have tried reseating all of the inks and and inks are still not recognized, Please contact Epson tech support for a replacement ink or if they find out after some diagnostics that it is the printer that is having an issue they would be replacing your printer.
Jun 22, 2008 | Epson Stylus CX9400 Photo Printer
670 people viewed this question
jasbo
jasbo
