Error code EOO on a Beko washing machine usually indicates a problem with the drying sensor. Here are some steps you can take to troubleshoot and resolve the issue:
Check the lint filter: A clogged or dirty lint filter can prevent the dryer from functioning properly. Clean the lint filter and try running the dryer again.
Check the vent hose: A blocked or kinked vent hose can cause the dryer to overheat and trigger the EOO error code. Check the hose for any obstructions or damage and clear them if necessary.
Check the moisture sensor: The moisture sensor detects the level of moisture in the clothes and adjusts the drying time accordingly. If it's faulty, the dryer may not be able to dry the clothes properly. Clean the sensor with a soft cloth and make sure it's not damaged.
Check the heating element: If the heating element is faulty, the dryer won't be able to produce heat and dry the clothes. Use a multimeter to check the element for continuity and replace it if necessary.
If none of these steps resolve the issue, you may need to call a qualified technician to diagnose and repair the problem.
Is there heat? Could be running cold if the elements have burnt out. If there is heat then check the pump and float switch that pumps the water from the sump into the condenser tray
Well the bad news is this is a extremely cheap unit. It was thought that a sensor that would know when your clothes were dry was a good energy saving idea. Well it wasn't This is a very common issue in these dryers. The Sensor needs to be replaced.
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Start button not working
