Question about Belkin (F5D5230-4) Router
Port??? When setting up the router for the first time does it matter what computer or port on the router I set it up with?
    Novelist:
    Scholar:
  • 128 Answers
The port on the router does not matter but you should set it up for the first time with the computer that was using the cable or DSL modem before you purchased the router. This will help in case you need to do any MAC address cloning.
Posted on Feb 16, 2006
I have a speedport W722V router with several computers conected using wireless network. A have also an Asus WL 600g router that I would like to use as an AP to enable me to use the USB printer port to...
configure the 600G to a static IP on the same subnet as the 722, and then wire it port to port (say, port 1 to port 1, do NOT use the WAN port) - don't forget to disable the NAT/DHCP on the 600G after you assign it's network IP address (not the WAN address, local address, the WAN port will no longer matter and will be unused on the 600G)
May 09, 2011 | ASUS WL-600g Wireless Router
Have Netgear wndr3300 router...has been in use with main desktop and 2 laptops running windows 7 for some time....son came home from army with an HP running Vista....no matter what we try...will not...
you might try a connection through the modem first to see if you can get a connection
check your son's computers settings ie: firewall also he might have a default internet setting you might have reconfigure all internet settings on his computer
check the leads from the router whether usb,ethernet make sure they are not bad/faulty and have secure connections or try different ports
click start control panel administrive tools computer management device manager scroll to network adapters + to expand any yellow ! ? or a red x will mean that the driver is corrupt and needs to be updated
hope this helps
Jan 17, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
My Netgear wireless router wgr614v7 has limited or no connection to computer through any of the LAN ports. LAN port 4 stays lit all the time, and is lit in conjunction when any of the other ports are...
Hello
There should be a reset button on the back that will bring this back to factory defaults. HOWEVER, every time I have seen "the light stay on" the router or switch was bad,. I would return this unit.
Best of luck
Nov 25, 2010 | NetGear WGR614 54Mbps Wireless Router...
When i type 192.168.2.1 it dosnt take me to the router set up page
connect the computer to the router and check the IP address on the computer. The default gateway will be the the number that will help you to open the router set up page.
If default gateway is 192.168.2.1 and still you are not able to open the set up, then try this way.
Click Start ==> RUN ==> in run type " http://192.168.2.1" and click OK.
I hope the following link will help you
click Here for more info
Nov 09, 2009 | Belkin (F5D5231V4-SN-PD) Router...
Netgear DGN2000: Only ethernet port 1 works. Lites work (flash green) for ports 2 - 4 but will not download Internet content. The browser indicates the site is found but downloading doesn't occur. I can...
Sounds like a configuration issue. With some routers you can set them up for bridging. Normally port 1 would connect your "bridge" and port 2-4 would connect your computers. You can test this by plugging your modem into port 1, and your computer in port 2. Power cycle your router and see if you get connectivity. It may be in your best benefit to reset the router to factory settings and see if 2-4 work with factory settings. After the reset, reconfigure the wireless side and your firewall.
Oct 26, 2009 | NetGear DGN2000-100NAS Router
Two pc connection by dlink switch
connect the router to the switch using any port-it does not matter which port you use. Connect each computer to any port on the switch-it matters not. The router will assign IP address to the computer as they are added.
DONE!!!
Good Luck
Sep 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Connection issue
Hi! I believe your having some issue with your router and I will be more than glad to assist you in this concern..Time warner cable is your isp and if the computer is connected directly to the modem, you have a perfect internet connection but if you are going to connect the cable from your modem to the router and you connect your computer to port 1 to 4 of your router it will not give u an internet connection. This is what we are going to do.
1. connect your computer that can get an internet connecttion thru time warner cable to the router on port1.
2. pull up a browser and type in the default gateway of the router, to check the default gateway of the router, right click the network icon on the lower right of the task bar and click status and it will show the ip address, subnet and default gateway, ex the default gateway is 192.168.1.1, u are going to type in the default gateway ip address to the url of the browser.
3. It will ask u for the username and password, by default the username is admin and the password is 1234 or just leave it blank.
4. It will pop up the setup page of the router and you have to look for the setting for doing a mac clone, you need to clone the mac address of your pc that can connect to the internet thru time warner cable modem.
5. once its done, save the settings and on the internet connection settings, manualy configured it to auto-dhcp. save the settings.
6. once its done..unplg the power of the computer, router and modem.
7. cable connection should be, cable from the modem goes to the WAN port of the router and connect cable on port 1 of the router to your computer on the lan port.
8. Plug in 1st the power of the cable modem, once all lights are lit then plug in the power of the router, once all lights are solid on the router, like the power, WAN, u will notice that there is no light on the port1, computer is still off, once the computer is on port1 will lit, then power on the computer..once computer is completely boot up, pull up a browser and it should gives u an internet connection.
9. Once you have an internet connection, u can access again the setup page of the router to setup the wireless connection settings.
10. If you are going to connect another to the existing router that is conneted to the time warner cable. that is possible, but before u connect the 2nd router to the 1st router..
a. connect the 2nd router to a computer to set it up..you have to access the setup page of the 2nd router.
b. once you access the setup page, there is a menu for the lan settings that is for the router side. u need to change the 3 octet of the ip address of the 2nd router. ex your 1st router ip address is 192.168.1.1 and the 2nd router ip address is 192.168.1.1 to change the 3 octet of the 2nd route, the 2nd router ip address should be 192.168.2.1. then save the settings..
c. the router will reboot and need to access the setup page of the router by using the 192.168.2.1 and u can set the wireless connection settings.. once its done..
d. cable connection should be---cable from the time warner cable goes to the WAN port of the 1st router, connect a cable to port 4 of the 1st router going to the WAN port of the 2nd router.. this process is called cascading two routers on a network.. this should work.. good luck
Aug 16, 2009 | ViewSonic (DHWMG120) Router
When we hook the wireless router to the modem and computer, we cannot access the internet. AS soon as we unplug it and put the computer and modem back the way it was, we can get back on the internet. How...
Log into the router so you can see the settings. Somewhere under WAN settings there should be something for you to "clone MAC address" click on that so the router clones the MAC address from the computer and this should work.
Sep 10, 2008 | Belkin Computers & Internet
Need help in connecting to the internet using Dlink 704p router.....
it doesn't matter whether the other computer is set to static and the other one is set to dynamic as long as both computers are getting/using valid ip addresses.
if i got it right. 1 computer is connected to the LAN port of the router and the other computer is connected to the WAN port. if so, you need to connect both computer to the LAN ports and the WAN port of the router should be connected to the modem that you are using.
if the physical connection is correct, check how you are connecting to the internet through the modem. if you can access the internet from the modem without configuring anything, you just need to power cycle. turn off everything then turn on the modem first, wait for the lights on the modem to turn on properly before turning on the router then turn on the computers.
hope this'll help you but if not, just provide the following:
(1)ISP:
(2)brand/model of the modem:
so i can help you further.
Jun 04, 2008 | D-Link DI-704P Router
Question
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Belkin (F5D5230-4) Router Logo
35 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
