Question about Belkin (F5D5230-4) Router
Setup I am unable to access the ?Belkin Gateway Router? setup screen, how can I get this to work?
    Novelist:
    Scholar:
  • 128 Answers
Make sure that the Router is ready and that it is detecting that the computer is connected. To verify this the Ready light on the router should be on solid and the light for the port that the computer is plugged into should also be on. If this is correct then all you should have to do is open up your Internet browser and type 192.168.2.1 into the address line and push Enter. If it does not come up with the log in screen then it is not connecting properly with the router. Try a different port on the router or a different CAT5 cable going from the computer to the router and try again. If that still fails, try emptying the Temporary Internet files cache folder and try again. If it still fails hold down the reset button on the back of the router for about 5 seconds or until the lights go out and start blinking. Wait for it to stop blinking and go back to the ready state. Try again to connect. Check the TCP/IP settings for the network card on the computer you are using. It should be setup to "Obtain an IP address automatically", if it isn?t change it and restart the computer. Once it is restarted, try again. If that still does not work type 192.168.2.1:88 into the browser address window.
Posted on Feb 16, 2006
Can't set up Belkin 54g Router with MTNL broadband
Samay,
You should reset your router to clear all information from it. The best procedure to fully clear your device would be to press the reset button with power on for 30 seconds; while continuing to press the reset button, remove power from the unit; and while continuing to press the reset button restore power for 30 seconds.
You should now be able to access the menus after the unit boots up with the default user name/password for the unit. If you do not know them, just Google [your router name] default user name and password. You can now set up the router to meet your requirements. There is a lot of information that will help you on the Internet, but having a clean booted router is important to start with.
Mar 17, 2014 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin router problems
Its not necessary to purchase a new router. Nintendo DS supports WEP encryption. You wont be able to connect if the encryption on the router is WPA. Your computer can connect on both WPA and WEP so what i suggest is for you to access the router page then check the wireless settings then change the encryption to WEP so that your Laptop and DS can connect at the same time. To access your router check the manual for the username and password
Thanks for using Fixya.
Aug 03, 2010 | Belkin (F5D5231-4) Router
How to restrict usage of my internet via belkin 54 g router gateway by my neighbours when they see my wireless connection,I mean how do I create a user name and a password where do i go step by step to do...
Follow directions in the manual to access the setup program built in to the router. This is usually done by using your web browser and going to an address like http://192.168.1.1 or whatever adress works with your router. After logging to the router, complete the Wireless setup. I prefer the WPA=PSK[TKIP] as it is more user-friendly on passwords. After this process is complete, you will need to use wnatever passphrase you choose to gain access to your router. You will need login info from your Owners Manual to get to the router's Admin program.
May 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How do i access my belkin 54g settings
To access in your router, open a blank Browser page and type :
http://192.168.2.1 normally it's this ip :)
(note that A lot of routers setup pages are accessed through [192.168.1.1]).
username : Admin and at password leave it blank otherwise Type : admin
Oct 15, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Unable to setup N Wireless Router in Apartment
Hi.
you do not have to run tye setup disk..
go to command prompt and do ipconfig
find the default gateway,launch internet explorer and in the address box type in the default gateway make sure the router is hardwired as sometimes it does not work on a wireless conection when you configure it.
If you get the router's console page it means that the router is getting detected(you can also ping the gateway on the command prompt to check the same)
on the console page you can fill all the settings and save them..the router will reboot and then you shold be able to use the router with proper internet and wireless settings.
http://www.ikarmatech.com
cheers.
Sep 11, 2009 | Belkin (F5D8231-4) Wireless Router...
Can not connet with my belkin router or get the configation page
If you cannot even access the belkin setup page, better try resetting it first by Pressing the reset button for 15 seconds while the power is ON and then try to access again the setup page of the it using a computer wired to the router if still cannot access it better call Belkin support and let one of their tech walk you through in checking the router hopefully its still not defective...
Hope that helps..........
Sep 17, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Secure wireless belkin g router
What is the exact model number of your router?
To access the router's set up page, you have to get the default gateway you see under status of your local area conection then type it on the address bar. You will then get a username/password screen, enter ur password and it will redirect you to the set up page where you can enable wireless security.
Aug 26, 2008 | Computers & Internet
Belkin (F5D5230-4) Router Logo
67 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
