Question about Belkin (F5D5230-4) Router
Connected?? How do I know if my DSL or Cable uses Dynamic IP, Static IP or PPPoE to connect to the Internet?
    Novelist:
    Scholar:
  • 128 Answers
The best thing to do would be to contact your Internet provider to be sure. There are a couple things you can check on your own that can help you determine this. When you use your DSL or Cable modem without the Router how does it work? Do you not have to assign any IP addresses or DNS settings to get it working? If so, that is a Dynamic IP Address setup. If you have go to into the TCP/IP settings and specify the IP address and the DNS settings that is a Static IP Address setup. If you have to click on an icon that goes through a connection process that uses a User name and Password, that is a PPPoE IP address setup. Once you are able to determine that you should be able to follow the instructions in the user manual.
Posted on Feb 16, 2006
SOURCE:
How to configure a router
  1. Login to the router page but typing http://192.168.2.1 on IE
  2. Check if you have a WAN IP or Internet IP
  3. If it is 0.0.0.0 then there is a problem
  4. If your internet provided is Cable you may have to do MAC clone
  5. If your internet provided is DSL you have to configure the router in PPPoE mode
  6. You will get WAN IP and will be able to go online
  7. Change the SSID which is nothing but the wireless network name
  8. Change the security to WPA or WPA2 and setup a security key
Aug 17, 2010 | Belkin (F5D7230-4) Router (587009)
Trendnet set up on my computer
-> Connect your Modem or Internet to the WAN port
-> Connect your computer to anyone of the LAN port
-> Check if you have internet
If not, You should be knowing what kind of Internet you have DSL/Cable
Check if YOu have a WAN IP. WAN IP should not be 0.0.0.0
http://192.168.0.1->Advanced setup-> System ->Status
xtjdeeblsvxsw4felwm6vryrdkruutd3bv9ylzur8ud+atfl9kwj992js4mrf2e4nktvap1qwkdy2svrtzxjy3g5vedqnwhg8bl3khhwclf9hbkld8fc7fjsw21zebaj4nff+s6a6bxuis4qsmahyc4suq69ujyv+8p8hc8qa+qfhffnqg2apvq72tgrqp4bmu7yiohsankn5fudyat1c8i6b4aj+gebdb8qa+qfeuguibfpjf8qaaud6o4sufb6p4ajdi8f8ddsvnsj0mvlmaaaaasuvork5cyii=
If it is 0.0.0.0
-> For DSL you have to configure it in PPPoE
-> For Cable you have to configure it in Dynamic IP and click MAC clone
Feb 28, 2010 | Trendware TRENDnet TW100 S4W1CA...
Im trying hook up a wireless router and it ask what kind of conection I have static ip ect... How do I know what I have? Im using DSL.
Most residential subscriber services use dynamic IP addressing. Dynamic IP addressing is automatic from your Internet Service Provider (ISP). Linksys home based products such as the one you have should be setup up for this configuration out of the box by default, and require no adjustments to the IP configuration of the wireless router.
You should power down the DSL modem and Linksys, then connect them, then reapply power. This will clear the DSL modem if it was connected to another device such as a PC. This is important as most cable and DSL modems use something called MAC address binding that will only allow one device to connect to it directly at a time.
Feb 06, 2010 | Linksys Wireless-N WRT150N Router
Belkin N Router does not recognise PPPoA connection type
First reset the router by pressing the reset button for 10 seconds while power is ON and then after that run again the setup , just to give you a clue which one to choose for the internet setup, if you use Cable internet select Dynamic and if you use DSL internet set it to PPPoE and provide your email and password from your DSL company...
Dec 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I have a belkin router N-150 F6D4230-4 and it has been hooked up for a while. Well, I had to get my internet turned back on today and now my wireless internet does not work. The modem light is flashing on...
It would be best if you setup the router again. Restore the router to factory defaults. Note: This will remove all previously configured settings "some router has reset button on the back of the router cover by a sticker. The reset button is small that you need a pen to reset it."
1.Unplug the power to the cable / DSL modem
2.Connect the power to the router.
3.Connect a computer to one of the LAN ports of the router.
4.Restart your computer.
5.From the computer connected to the router, open your web browser (internet explorer).
6.Enter the router's address, http://192.168.2.1
7.Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
To configure the router to connect to the Internet, you must enter information provided by your Internet Service Provider (ISP) into the "Connection Type" section in the left-hand column under the "Internet WAN" heading of the router's configuration page. If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider, the static IP fields (including network mask and gateway) must also must be set in the router.
ISP Connection Type
AT&T PPPoE
Charter PPPoE, Dynamic
Comcast Dynamic
Earthlink PPPoE, Dynamic
Qwest PPPoE
Road Runner PPPoE, Dynamic
Verizon PPPoE, Dynamic
8.Plug the power back into your Internet modem.
9.Verify that this computer can connect to the Internet properly. Open a new web browser and visit a few Internet sites such as Google.com or Yahoo.com.
10.Finally, configure additional network security features as desired to guard your systems against Internet attackers
If issue is not resolve you can contact your Internet Service Provider for assiatnce.
Nov 20, 2009 | Belkin Computers & Internet
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Belkin not working
Do you have your router set accordingly for static or dynamic IP> Check with your internet service provider for the following information. Static IP or Dynamic IP.? PPPOE connection. DSL or Cable. Then program your belkin acording. Oh and your belkin may have a connect on demand feature. you want to have this disabled.
Feb 18, 2008 | Belkin (F5D7230-4) Router (587009)
Get router started
Have you tried entering your username and password for your isp provider? You have to enter the config page of your router and enter this information there.
Jan 31, 2008 | Computers & Internet
D-Link DSL-2640
First I will need to know the type of ISP service you have, T1 - DSL - ADSL - CABLE - etc. And the connection type, STATIC IP - DYNAMIC IP - PPPOE - etc. BPCS
Dec 11, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
Setting up a wireless router
first you have to check the ip address of the dsl modem you used and see to it that it is not the same ip address of the router to avoid conflict. the default ip address of dlink router is 192.168.0.1.if in case your dsl modem has the same ip address with the router, you have to change firs the ip address of the router before connecting the router to your dsl modem.
next you need to know your internet connection whether it is DYNAMIC or PPPOE, depending on how your internet provider configured your modem. for PPPOE connection, you have to know the USERNAME and PASSWORD that your provider provides you.
good luck.
carlmali007@yahoo.com
Nov 30, 2007 | D-Link DI-624M Router (DI624MRE)
Belkin (F5D5230-4) Router Logo
93 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
