Question about Medion Computers & Internet
Desktop reboots intermittantly. I have a model PCMT6. Seems as though it might be a power supply?
I had a similar problem, I replaced the power supply, cost $25, now my Medion works better than before. It was easy & I'm no electronics wiz.
Posted on Sep 27, 2008
Acer Veriton 6900 Desktop says no signal and the screen turns off. The towers power light stays on but the fan isn't running.
Change the power supply and restart your pc. This will happen when the power supply has gone bad. It sends power to low voltage items but not the needed voltage to power the system on.
Good Luck
C2Solutions
Feb 14, 2012 | Acer Veriton 6900 PC Desktop
My acer aspire X1200 b601a wont boot past first POST screen, ive tried reseating the CMOS, but seems to have made it worse. it contains all original parts, though take into account that it was FACTORY...
IF the machine is just shutting down it's likely the power supply. If it's constantlly rebooting itself, it's a corrupt bootlog. If the machine is just "freezing" when it tries to boot, it's likely motherboard related.
Oct 09, 2011 | Acer Aspire X1200-B1601A PC Desktop
I have a dell smart step 100 d its constantly rebooting
Hello.
Even though you said that you changed every piece of hardware, just for good measure I wanted to tell you that there are three reasons that a computer reboots itself: 1. Memory, 2. Power supply 3. Operating system problem, such as malware.
Hope that helps, although you may have done the above.
Nov 05, 2009 | Office Equipment & Supplies
Palit Geforce 8800gt 1Gig Glitches + BSOD
Nvidia's recommendations for the 8800GT are 26 Amps (I think) on the 12V rail... Although you would think 20 Amps would be enough, my next step would be to uninstall the video card driver again, get yourself a copy of a program called Driver Cleaner dot net, run the program in safe mode to completely remove all of the Nvidia driver, then reboot into Windows, download the latest WHQL driver for your card from nvidia's website, and see if that fixes it. If not, either try the card in a system with a more powerful power supply, or get a more powerful power supply, and see if your error goes away.
Dec 24, 2008 | Palit Microsystems GeForce 8800 GT,, PCI...
Intermittently After Startup the PC Reboots Automatically
I think its a heating problem try to clean all you fan also the graphic card. you can look in your bios an see the processors temparature how high it is.
it can also be the powersupply or if you have stream picks in your
electricity network.
you can test if its a heating problem to play a
resource demanding game or program. if its a heating problem your computer gonna restart when you put your processor on press.
Jul 17, 2008 | Acer Aspire T310 PC Desktop
Computer rebooting
Backup your files and reinstall your windows!
Jun 17, 2008 | Systemax Venture PC Desktop
GRAPHICS CARD
Its most likely the video cards fault,
however a bad PSU can cause these problems.
No Power To The Computer
Here you must first check the wall outlet for power by connecting another device such as a radio or lamp to be sure power is present. If the computer is connected through a surge protector, check it as well.
If the wall out has power, check the power cable going to the PC to see if AC voltage is making its way to the system unit. Do this with the use of a multimeter.
If there is power, you will have to open the PC and check for power from the power supply to the motherboard.
When using a multimeter to check voltage, be sure you have a good ground for the black lead of the multimeter.
Rebooting Problems
One main problem you may face with an ailing power supply is that it may reboot the computer without any warning. All information is lost and it seems as though this happens at the worst possible time.
Booting errors when the computer first starts up may be another indicator of this component going on the blink.
Power Distribution Problems
When the power supply begins to fail, you may receive power at one device and not another. For example, the hard drive may receive power, but the CD-ROM drive has nothing at all.
Another headache that would cause rebooting is the intermittent power going to the drives or the motherboard itself. Follow the steps below to check your power supply should you experience some of the above problems.
Nov 20, 2007 | Nvidia GeForce2 MX400 Graphic Card
Reboot w/ new power supply
I recomended you first to clear cmos settings and check the ram!
Check the hdd if it is OK?
USE ORIGINAL CD TO REPAIR ( REINSTALL ) OS!
Let me know if u get help???
Oct 31, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
82 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
