Question about Maytag Neptune MDE5500AY Electric Dryer
Need to clean Maytag Model 5500 electric dryer
How do I open this dryer model up to clean it?
  • 943 Answers
Posted on Sep 12, 2008
Model #MDE8057AYW I need to know how to get the lid off so I can see if I need a new belt
1.Unplug the electrical cord of the Maytag electric dryer from the electrical outlet.
2.Open the dryer door and locate the four screws on the inside,unfastening the screws with a screwdriver.
3.Pull on the corners of the top front panel,rolling the corners forward to release the clips.
4.Tip the front panel straight out and slide it up until the panel comes loose of the clips.
5.Set the front panel aside and slide the top of the dryer forward.
6.Lift the top of the Maytag electric dryer up,tilting it back and resting it against the wall.
Aug 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag dryer and i need to know if it is electric or gas. model # (P)MDG4000BWW
Gdeli25 --
The Maytag Neptune MD[G]4000BWW is a front-loading [G]as dryer. Parts list and manual are available online from:
If you are still having problems, write back. -- SWT
Aug 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag model HYE3657Ayw how can I open it up to clean lint inside the cabinet
first pull it away from the wall, then clean out the lint from the vent, then you will need to pull the front panel off, you should find 2 screws inside the door opening, and then you will need to pop loose the tabs from the bottom
Jul 10, 2009 | Maytag Neptune MCE8000AY Electric Dryer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dryer doesn't work,electric has been checked I
You dont need to check motor first. start from door switch. check the continuity of the switch if not making a peep sound when you press the button replace the switch button.
Apr 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I need to get to the gas controller on my maytag 5500 dryer.
Hello jp_wilson
Welcome to Fixya
My name is Huum,
At this site is the schematics and diagrams of the unit
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Watt for dryer
Total 5500 watts for motor timer and heating element on an electric model. (estimated)
Jan 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer model 4000, <10 y.o., hums, but won't start.
I wouldn't know about the warranty, but the dryer motor may need only a start relay, which is usually attached to the motor. Usually, this is a centrifugal device. By that I mean the contacts on the relay are normally closed to give the motor extra starting capacity when you first turn it on. The contacts open after the motor get up to full speed.
Jan 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Remove front of dryer to clean lint from interior
open door remove eight screws, four on plastic guides and same location on hinges. wiggle door and it will remove . now grab narrow ends of front panel and pull toward you. wwhen panel gets to 45 degrees pull off tabs at bottom.
Jan 30, 2008 | Maytag MDE9316 Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
117 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
