Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Pink hue our tv gets a pink hue. we've adjusted everything we can think of and can't get a decent picture without having any pink in it
    Problem Solver:
  • 39 Answers
Remove speaker grill, manually adjust red drive untill red is normal.
Posted on Oct 02, 2008
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
The picture is so dark can't make out figures
It sounds that the back-light section has some fault with your TV. Otherwise, 30% brightness, 60 to 65% contrast, and 20 to 30% color settings should give you perfect picture.
Jun 06, 2013 | Digimate DGL20 Television
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
Jan 24, 2010 | Fuji FinePix V10 Digital Camera
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Everything's magenta!
Check in your printer driver settings "advanced" section, and see what the presets are. if the RGB or CYMK settings have a slider, see if the magenta is set at 100%. If it has a slider, try it at 90%, 80%, etc until you have a less pinkish hue. You can then create a printer profile which will work with the photo paper you are using.
Different photo papers can cause hues like this.
Also, you can remove pink any unpleasant hues with most photo image editors through color correction.
It's possible that you have a contaminated cartridge...especially if it's a refilled tri-color cartridge.
Dec 09, 2008 | Canon Office Equipment & Supplies
50V720 w/pink hue over entire screen
The light engine will need to be replaced. Without a warranty the part is very costly. You are lucky...
Nov 29, 2007 | Hitachi 50V720 Television
Picture problems
My computer did this and I think my TVs just gone the same way. Was definitely a loose connection somewhere. In the computer monitor it was because the pins in the plug were slightly bent and if I moved the wire the picture got better. In the end I had to replace the connecting cable
Mar 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
298 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
