Question about Dryers
There's hardly any heat coming out of the dryer at all' can you help?
  • 374 Answers
You probably have a heating element burnt out. You did not state if it was a gas unit or electric so I am going with electric.
Some dryers have a two part element that allows one to go out while the other is still functional. You can also check the receptacle to ensure that you ar egetting the currect voltage there. I would also check at the cord terminals as well. You can find parts at partsstore.com etc using make and model numbers.
Posted on Sep 09, 2008
Dryer will not come on....flipped breaker and still no power
Sorry to read about your problem, I hope this helps you out.
You must have a defective heat coil, it broke and is grounding out. or a hard short on your motor.
I suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Roper REX3614KW Electric Dryer
My gas dryer has stopped heating up. The egnighter light comes on but the gas doesn't go on. How easy or hard is this to fix?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 20, 2010 | Maytag Dryers
Not heating up
Without knowing the model number, it is hard to be specific but...
If it is an electric dryer, the most common cause for the problem you report is a failed heating element. Many times, the wire that heats up is actually burned through. If you inspect it yourself, it is important to unplug the dryer before you open up the rear of the dryer.
Please post back with what you find or have further questions, OK?
Aug 13, 2009 | Whirlpool Dryers
Dryer is not drying, no heat
your dryer has a coiled unit inside that heats up...this is what actually where the heat comes from is off this coil. Your coil (heat element) has a break in it some where this be the reason for your dryer not heating up. As for VERY temp solution..one could twist this heating element together making connection but again this is JUST to be temporary ..as only should be 1 day before actual heating element to be repaired correctly. If one is mechanically inclined this is not a hard procedure with the correct common tools...and heating elements can be bought offline as well as possibly if you have a Sears repair facility close by your loction. IF not, then suggest you to call a trained tech in this field if you are not mechianically inclined or unsure of yourself.
Jul 04, 2009 | Whirlpool GGQ8831L Gas Dryer
Heating element
You can get to it threwthe back panel with a 1/4 in socket driver.Take the panel off and you can see the element,not hard to replace.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 15, 2009 | Kenmore 63942 Dryer
Dryer won't heat up
It could be the problem, you are definitely on the right track. There are a lot of things though that could cause a dryer to not heat. I try to give the most common reasons as it is hard to determine without hooking up a voltage meter to the parts. One thing is that your vents may be clogged up somewhere between the dryer and the outside. A lot of people don't want to believe that the problem is that, but it is common and if that is the problem better to be that then something wrong with the dryer. Anyway, check outside where the vent is and feel if the air coming out is strong. If it's not that may be the issue.
Next, if the air is good, open up the bottom panel so you can watch the dryer working. Watch and see if the ignitor is coming on. You may just have a problem with the thermostat which tells the dryer when to shut off the heat when the temp in the drum has reached the max. It should go up to about 110 degrees and then turn off, when it gets down to about 70 or so it will come back on. That is the job of the thermostat, to regulate the temp. If it does not work though it just won't heat.
If your ignitor does come on and you see the flame and it goes right off then you need to replace the thermostat. If it doesn't come on at all though you will need a new ignitor seloniod. Let me know if you have any other questions and let me know if this was helpful for you. It might be wise to have a tech come out and fix it too as some of those things can become quite a pain to fix. Gas dryers are a lot more complicated then electric. Good luck and glad to help.
Jan 22, 2009 | Kenmore 73952 Gas Dryer
Roper Dryer not Drying
Get a thermostat and place it in the exhaust. The thermostat should reach 160 and then shut down and drop to 120 F and start back heating to 160 again on cotton setting. You should hear an audible click when the thermostat opens and closes. If the dryer is clear of lint and blockages then change the control thermostat which is mounted on the blower housing.
Sep 07, 2008 | Roper REX3614KW Electric Dryer
Not drying no heat.
be element are thermo fuse on element no easy to change remove 2 screws on door hinge 2 screws on the ather side frount comes off there the element
Feb 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Not geting hot enough
The most common thing to cause this is a blocked vent. Start the dryer and go out to where the vent comes out of the house and see how hard it blows. If you feel little air out the vent, you will need to unhook the dryer from the vent and see how hard it blows there. If it is blowing good there you need to have the vent pipe cleaned. If dryer isn't blowing hard out the back, please reply back with the model number so I can give more detailed directions on checking the blower wheel and ducts.
Oct 11, 2007 | Kenmore 74602 Gas Dryer
Dryers Logo
Top Dryers Experts
