Question about Belkin (F5D5230-4) Router
Cant access router screen or get on the internet after updating the firmware
  • 128 Answers
Re: Cant access router screen or get on the internet...
If you have updated the firmware for your router and you can no longer access the router screen please follow these steps and you will regain access to that screen. In the browser address bar type in If you still cannot access the screen, follow the instructions below. FOR Win95, 98, 98SE, ME: 1. Right click on Network Neighborhood. (you should see the icon on your desktop, or for winME it will say My Network Places) 2. Double click on TCP/IP for your network adapter. 3. Select ?Specify an IP address? and type in For the Subnet Mask use 4. Then click on the DNS Configuration tab and select Enable DNS. For Host name you may assign whatever name you prefer. (ex: your name, or your computer name) Leave the Domain name blank. Under DNS search order, type in and click add. Then add 5. Click on the Gateway tab. Under New Gateway, type in and click add. 6. Then click ok. Click ok again and you should be prompted to restart. 7. Once the computer is restarted, open your browser and in the address bar type in You will get the router login screen. If you get a screen that says Recovery Micro Code, that means the update didn?t go through and you will need to update it again. For Win2000, XP: 1. Go to your control panel and double click on Network Connections (for winXP you have to select Network and Internet Connections, then Network Connections) 2. Right click on your Local Area Connection and go to properties. 3. Double click on Internet Protocol and your TCP/IP properties should open up. 4. Select ?Use the following IP address? and type in The Subnet Mask should be 5. For the Default Gateway use 6. Select ?Use the following DNS server address?. For the Preferred DNS server type in For the Alternate, type in 7. Click ok, then click ok again and restart your computer. 8. Once the computer is restarted, open your browser and in the address bar type in You will get the router login screen. If you get a screen that says Recovery Micro Code, that means the update didn?t go through and you will need to update it again.
Posted on Feb 16, 2006
0 characters
3 Points
My links wireless g router will not stay connected to my house internet I must unplug it 20 times a day ill connect for ten mins then say limited access n not connect
Update the Firmware to your router to do that do the following. 1.In your address bar on your browser erase address. 2.Type in 3.The tabs to the left you will see firmware update click it and it will automatically look for updated firmware. If this does not help you can download the firmware from the direct website here is the website.
Feb 15, 2011 | Linksys Routers
I have a wireless 300n 3g router witch i cant get working... i can access the router trough wireless and wired connections but wont let me access the internet.. i have an eircom 3g stick plugged into it...
Hi,Just go to the Intellinet website and download the most recent Firmware with Modem update. I had the same problem with one of the latest 3G modems and the latest firmware had that sorted out.
Dec 27, 2010 | Intellinet Active Networking (520638)...
This modem does not save settings. Like when you open your nat. How do i update my firmware
Check the latest firmware updates at
Or simply, access the setup page of the Belkin router (, go to Utilities > Firmware update. Click on the Check firmware button.
Then click the download link. And save the firmware on your desktop.
In the firmware update screen, click browse and locate the firmware from your desktop.
Then click the Update button. Click OK to continue with upgrading.
I hope this helps!
May 15, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
D-link DI-808HV - no response after firmware upgrade
Unfortunatly, from what you are saying it seems that the router is dead.
Mar 10, 2010 | D-Link DI-808HV Router (280006OB)
Belkin N+ keeps dis-connecting from internet
u can try dowloading the latest firmware for the n1vision router...
here is the link....
download appropriate version and save in the hard disk.... login to router page... type in internet explorer... password leave it blank and click submit.... click update firmware on the browse and update the firmware dowloaded... after updating, login to the router page again and click on restore factory defaults(must)....your problem ll be rectified....
Feb 24, 2010 | Belkin N1 Vision Router
Downloaded firmware for my actiontec router and it screwed it up
please help me i have internet on my pc but i dont know how get internet to my psp
Jun 20, 2009 | Actiontec GT704WG Wireless Router...
Playstation 3 disconnecting from wireless gaming
Linksys loves to ship their routers with out-dated firmware. If you haven't updated the firmware of your router, that would be the first thing I'd do. From what I've read about routers and PS3, a lot of routers had trouble when they came out but had firmware updates to resolve the problem.
You'll need to go to the below link and select your version to get firmware downloads specific to your Model router and version number. The version number is listed on the bottom of your router next to the model.
Be sure to read up on how to update the firmware and be sure you only update the firmware from a computer connected via WIRED connection to the router. Doing it wirelessly will cause disconnection from the router mid update and will cause your router to become a paper-weight!
The above link is a good website to find out a lot of information about Linksys routers and how to secure/update/configure them.
Mar 04, 2009 | Linksys Wireless-G WRT54G Router
I have a linksys wrt150n wireless router
Do you see the wireless light blinking? IF yes then there are a few things you should try.
1. Factory reset. Press and hold the reset button for 10 seconds then reconfigure your router and see if it resolves the issue
2. Firmware update. Download the firmware update and then access you router and click on firmware update and browse for the update you have downloaded(you have to extract it first just in case its zipped) Hopefully that will do the trick.
If none of the these work then its a hardware fault and you will have to get your router serviced!
Mar 01, 2009 | Linksys Wireless-N WRT150N Router
All I did was reset my Router Now it says i'm coneccted but nothing.
You need to access the router setup page:
To access the configuration utility, open a web-browser such as Internet Explorer
and enter the IP address of the router (
Type “admin” for the User Name and “admin” in the Password field.
To access the FIRMWARE UPDATE setting window, click on the Firmware Update button under the MAINTENANCE tab.
To update firmware, click on the Browse… button to
search for the file and then click on the Update
Firmware button to begin copying the file. The Router
will load the file and restart automatically.
May 11, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Router won't hold connection
Update the firmware of the router by going to Belkin's download site. Save it on your computer and access the router's setup page by going to, go to firmware update option then upload the new firmware on the router.
Or call the toll-free Supportrix Tech Support at 1-877-787-8749 and give "support call" as promo code for one free technical support call.
Apr 19, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D5230-4) Router Logo
74 people viewed this question
Top Belkin Routers Experts
 C. Dante
C. Dante
steve morris
steve morris
Are you a Belkin Router Expert? Answer questions, earn points and help others
