Philips Magnavox 51MP392H Rear Projection Television Logo
Posted on Aug 21, 2011
Philips magnavox,9p5040c102 tv has power but no pic or sound, what is wrong, worked fine yesterday
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
115
Points
I have same problem with mine, the power button turns red (as usual) but no picture. When i turned mine on last night it made a crackle noise and thats how it all started. I can even hear the normal sounds it makes as if it were turning on, but still no picture. Its a great tv I would hate to throw away. I want to fix it myself any help would be appreciated!
My philips tv keeps losing the picture, still have the sound in the background but no pic, this has happened before and then went back to working fine, but yesterday turned on the tv, it worked for 5 secs...
Check if the tube lights up at the rear, the fillament must glow.If not check for badly soldered joints at the picture tube connection or the HT transformer.
8helpful
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Television won't turn on
Sounds like a power supply problem, you'll have to take it to a repair shop to fix that unless you know electronics. Good luck.
Magnavox TV
it is very possibvle that the three lights are not positioned correctly or you may have to change the fluids behind the lights only a technician can do this
Philips Magnavox, no cule model num
hi there,
could be regulator in power supply,there are like 3 ics in charge or the regulation,ask him to get schematic for this tv and find regulator ics one ar more of them could be bad,thanks.
Magnavox 9p6444c102
I had the exact same problem with my Magnavox TV. No sound and no video but the power light was lit.  You can find the solution here.
http://www.magnavoxhelp.com
50 in. TV
thats the PTV910 -914 series philips. If you have some trouble shooting abilities you can get the service manual for your set at the following link and they will also provide free support to help you diagnose and repair the set. Your model is coverd in the manual for the 60P8431.under the phillips/magnavox section.
Heres the link.
http://servicemanuals.vstore.ca/
2helpful
2answers
Philips magnavox model# 9p5040c102
Goto www.TvRepairKits.com and get their shrinking/expanding video repair kit. It works on the Philips sets.
No pic
Sounds like a high voltage issue and/or a power supply problem.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
