Question about Belkin (F5D5230-4) Router
How can i verify??
How can I verify that all my Internet browser and computer network settings are correct for use with the router?
    Novelist:
    Scholar:
  • 128 Answers
If you use Internet Explorer: Go to Start, Settings, Control Panel, Internet Options, Connections, and the LAN Settings button. Clear all checked settings in this window. Then, open your browser and select the Tools menu. Under Internet Options, click on the Connection tab and make sure that "Never dial a connection" is selected. If possible, remove all the connection settings. If you use Netscape Navigator: Go to the Edit menu and select Preferences. Go to Advanced, Proxies, and click "Direct Connection to the Internet." Also check for the following. If you are running Windows 95 or 98 or ME: Click on the following tabs and write down the settings you find. Right-click on Network Neighborhood and select Properties. Select "TCP/IP" for your network adapter. Then click Properties. Click the IP Address tab and select "Obtain an IP address automatically." Under wins configuration, click on use DHCP for wins resolution Click the Gateway tab. If there are any "Installed gateways," highlight them and click Remove. Click the DNS tab and select "Disable DNS." Click OK If you are running Windows NT: Write down any settings you see throughout the tabs for future reference. Right-click on Network Neighborhood and select Properties. Click the Protocols tab, highlight TCP/IP, then click on Properties. Click the IP Address tab and select "Obtain an IP address automatically." Remove any gateway settings you see. Click OK. If you are running Windows 2000: Right-click on My Network Places. Click on Properties. Right click on the Local Area Connection icon that connects to the Router. Click on the Properties button. Highlight TCP/IP, then select "Obtain an IP address automatically." Click OK. Go the the advance tab, click on wins, check the box use NetBios settings from the DHCP server. If you are running Windows XP: Click on My Network Places. Click on view network connections. Right click on the Local Area Connection icon that connects to the Router. Click on the Properties button. click on the advance tab, make sure the internet connection firewall is not checked, click ok,Highlight TCP/IP, then select "Obtain an IP address automatically." Click OK.
Posted on Feb 16, 2006
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
How to connect to internet. what are the instructions... because my router have a signal but it cant connect to internet
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop/Desktop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
You will also need to configure your browser for the internet
1. for Windows XP here is the setup :
http://www.microsoft.com/windowsxp/using/networking/default.mspx
2. For Windows 7
here is the setup instructions: getting online and networking
http://windows.microsoft.com/en-US/windows7/help/networking-e-mail-getting-online
http://windows.microsoft.com/en-US/windows7/View-and-connect-to-available-wireless-networks
Apr 07, 2011 | Computers & Internet
How do i set up model number f507632-4
  1. Choose a convenient location to begin installing your router, such as an open floor space or table. This does not need to be the permanent location of the router. For wireless routers, it may be necessary to re-position the unit after installing it as the signals may not reach all areas needed.
  2. Unplug the power to your Internet modem.
  3. Power down your computer(s).
  4. Plug the power in to your router.
  5. Connect your Internet modem to the router. The cable plugs into the router jack named "WAN" or "Internet". Turn on your Modem.
  6. Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable.
  7. Turn on the computer.
  8. From the computer connected to the router, open your web browser. Enter the router's address, http://192.168.2.1, and press Enter on your keyboard.
  9. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  10. To configure the router to connect to the Internet, you must enter information provided by your Internet Service Provider (ISP) into the "Connection Type" section in the left-hand column under the "Internet WAN" heading of the router's configuration page. If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider, the static IP fields (including network mask and gateway) must also must be set in the router.
  11. If this is a wireless router, change the network name (referred to as SSID). While the router comes to you with a network name set at the factory, you may want to use something more familiar for your network. Read Changing the router's wireless channel and SSID for a description of this process.
  12. Plug the power back into your Internet modem.
  13. Verify that this computer can connect to the Internet properly. Open a new web browser and visit a few Internet sites such as Google.com or Yahoo.com.
  14. Finally, configure additional network security features as desired to guard your systems against Internet attackers.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | Belkin (F5D7633UK4A) Wireless Router
My Linksys router went off, and when I tried to reset it, it reverted to the general linksys name on the wireless networks but I still can*t connect to the internet wirelessly, only if I use a direct cable...
If you have power and you can connect via Ethernet cord no the router is ok.
You will need to set the wireless settings correctly in the router setup page.
instruction set here:
7. Move the laptop about 20ft away and try to log on to the internet.
Oct 11, 2010 | Linksys Wireless-G WRT54G Router
Times out, and kicks all off internet
2. For Windows 7
Oct 08, 2010 | D-Link AirPlus DI-524 Wireless Router
I have a connection to the network but no internet activity
check the ISP to verify the connection to your home
2.You will also need to configure your browser for the internet
a. for Windows XP here is the setup :
b. For Windows 7
4.. Check the laptop/desktop do ipconfig /all to see current IP addresses.
Oct 07, 2010 | Acer Computers & Internet
I am not able to connect to my Belkin Router. My roommate has a Mac and it works great for him, but my PC will not connect to the internet through the router. He set up the router using his computer. Mine...
2. For Windows 7
Oct 05, 2010 | Belkin (F5D7231-4) Wireless Router
One of my computer will not connect to the internet when hard-wired through this router. Others do work and the wireless works flawlessly. The computer in question runs XP and can communicate with the...
1. There may be 3 issues here to consider 1st :
a. the network card \
b. the Ethernet cable
c. the Ethernet port on the router defective.
2.Here is a instruction set to follow to see if your router is connected properly with the said pc :
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or firefox) on the computer that doesn't connect.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
7. use a straight through Ethernet cord ( a know good one )\
8. verify that the network card is working by using a loop back ( that is ping the NIC card ( done by using dos command prompt>> loopback address is 127.0.0.1 this should yield 4 hops complete if the NIC card is working ( NIC = Network Interface Card)
I hope this helps. Have a great day!
Aug 23, 2010 | SMC WBR14-N Router
It says that my computer is connected to network and internet but it my computer cant browse in the internet
Likely a DNS problem.
1. Check to see if your router is set to obtain DNs as dynamic or static (probably dynamic). Verify the listed primary & secondary DNS servers are correct for your ISP.
2. Check router to see if it acts as DHCP server for your network to assign ip numbers to clients. If so, then verify your computer as dynamic, otherwise set static ip in the same subnet.
3. Verify gateway assignments.
May 16, 2009 | Computers & Internet
How To Set Up PPPoE DSL Connections with a WRT55AG Router
STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to clear the ?Password? field before entering your account password. AOL USERS: Enter in your PPPoE username as screenname@aol.com. 6. If the Keep Alive option is not selected, be sure to select it instead of the ?Connect on Demand? option. The ?Keep Alive? option will ensure that your connection stays connected even when it is not in use. 7. Scroll down to the bottom of the page and click on the Save Settings, or Apply button depending on router model, to save your changes. OR 8. Once your changes are saved, you will be presented with a button to return or you will be returned to the previous page automatically. If prompted, press Continue to return to the router?s Setup page. 9. Close and exit the web browser. STEP 5: Power Cycle Follow these steps to power on and off your devices in the correct o
Feb 16, 2006 | Linksys WRT55AG Router
Belkin (F5D5230-4) Router Logo
95 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
