Question about Lexmark Office Equipment & Supplies
I have lexmark X6575, receiving message, unable to load JIT compiler mscorjit.dll file may be missing, please re run setup. I have unistalled/reinstalled , message remains.
    Problem Solver:
I was able to fix the problem with my lexmark X6575, activating the printer from the desktop icon and to use the fax, utilizing the utility tools provided by your expert. Lexmark could not provide the solution, and I am still waiting for them to tell me what the proiblem was. Your expert found the solution very fast. Thank You, I will call you again for help when I require in future.
Posted on Sep 08, 2008
"setup was unable to copy
See, "setup was unable to copy the file F:\vb.net \vs2008\readme.htm to your temporary directory .Please make sure that this file exits and rerun setup" its mean the file readme.htm is missing in setup folder of visual studio 2008. So, for this first you have to simply download readme.htm file http://www.microsoft.com/en-in/download/confirmation.aspx?id=5478 and download direct in your visual studio 2008 folder. Then refresh the folder of visual studio 2008 and run or doble click on setup file.
It will work. :) thank you.
Feb 27, 2011 | Computers & Internet
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
May 29, 2010 | Dell Studio XPS 16 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Missing dll file for printer
Hi Hansel,
You can download the driver for yourX3350 from the below link.
Lexmark X3350 Driver.
You just choose the operating system and download it.
-Rate if it helped you.
Apr 12, 2010 | Lexmark X3350 All-In-One InkJet Printer
Unable to access Kodak EasyShare software
Perform a clean uninstall:
1) uninstall the software from your OS
2) run the clear utility program www.kodak.com/go/clear
3) type "regedit" w/ out the quote on the run command, then delete hkey_local_machine\software\kodak
4) run disk cleanup
remove the ff:
  • Downloaded Program Files
  • Temporary Internet Files
  • Recycle Bin
  • Temporary Files
5) reinstall the software again at www.kodak.com/go/edl
May 29, 2009 | Kodak EasyShare Z760 Digital Camera
MLANG DLL. IS MISSING
This happened with MS Windows some times if you don't want to say..it's often :)
Okay, this what you should do:
Download the missing file from here: http://www.dlldump.com/cgi-bin/testwrap/downloadcounts.cgi?rt=count&path=dllfiles/M/MLANG.DLL
Then, follow the instruction below:
How to install/uninstall MLANG.DLL? 1. Unarchive the package and use the files from Release folder if you're running windows 9x/Me or Release Unicode if you are running windows 2000/XP
2. Copy DLL files in system32 folder [C:\WINDOWS\system32]
3. Click on Start > Run
  • To install the dll files, type: regsvr32 MLANG.DLL
  • To uninstall the dll files, type: regsvr32 -u MLANG.DLL
  • run.gif 4. In the end, you should receive a message saying that your file was successfully installed/uninstalled
    P.S.: If this information was helpful, please rate this solution.
    Mar 23, 2009 | Microsoft Windows 98 for PC
    76 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
