Question about Acer AL1717 17" LCD Monitor
My monitor has a very bright background that white pages seem hard to read and video quality tends to be poor, even if i adjust the brightness levels it doesn't help...it is an acer AL17171F model, what can i do please emma uganda
    Problem Solver:
  • 11 Answers
If you can fix it your self,open the power supply and look if the capacitors after the chopper transformer are swollen if yes change them,or take it to an tecnician expert to do that for you
Posted on Nov 11, 2011
SOURCE:
Computer screen looks overly bright
please adjust Brightness and contrast at comfort level. if problem persist reinstall graphic drivers.
Jan 22, 2014 | Dell Inspiron One 2020 All-in-One Desktop
Background too bright
What about the TV reception? Is it alright?
Apr 29, 2012 | Televison & Video
I am running two monitors; a Dell and an HP vp17. The Dell's color looks bright and clear. I am currently using it as my default or number 1 monitor. The HP colors are dull and the photo I am using on...
You will just basically have to go through the menu settings on the monitor and adjust the color,contrast, and brightness. No two brand of monitors are going to be the same. Even different models of the same brand will very.
Jan 24, 2011 | HP vp17 Monitor
Why video quality in mac is not good it seems
Try going to your System Preferences which is in your Utilities folder located in your applications folder. In system preferences, click on the button called "Displays"... from there, adjust your brightness (turn it up).
Also, if video quality is bad in Quicktime - open quicktime and go to Window tab located at the top right near the help tab. Then click on Show AV Controls. You can adjust brightness from there.
Also, within the Displays button, try calibrating your monitor by following the simple instructions.
Apr 15, 2010 | Apple Mac OS X 10.4
My monitor stays white it wont show any display
black-icon.gif This icon indicates the BRIGHTNESS control, more properly called BLACK LEVEL. It adds or subtracts an offset, or bias, into the red, green, and blue signals. This control should be adjusted so that black picture content displays as true black on your monitor. Misadjustment of this control is the most common problem of poor quality picture reproduction on computer monitors, video monitors, and television sets. Later in this document, I will explain how to set this control properly. The setting is somewhat dependent upon ambient light. Modern display equipment is sufficiently stable that frequent adjustment is unnecessary.
picture-icon.gif This icon indicates the CONTRAST control, preferably called PICTURE. It applies a scale factor (gain) to the red, green, and blue signals. It affects the luminance (proportional to intensity) that is reproduced for a full white input signal. Once BRIGHTNESS is set correctly, CONTRAST should be set for comfortable viewing brightness.
The gamma can be controlled through Video Card utility which can usually be accessed by going to display properties.
Depending on your video card software you may be able to right click your desktop, select properties, select settings tab and then choose advanced, towards the bottom. In there you may find a tab called Monitor and under that tab you may or may not (depending on your video card software) be able to adjust your color correction settings(gamma & brightness & contrast).
. Right click on the desktop and then select Properties
2. Click on the Settings tab and then click on the Advanced button.
3. Click on the Color Correction tab and you will see settings for Brightness, Contrast, and Gamma
Jan 29, 2010 | Computers & Internet
Screen returned from supplier background bright pink, how do I change to white background.
To check if the video card or the Sharp LCD monitor is faulty, connect a different monitor to the computer. If this monitor displays a normal image then the video card is OK and the Sharp LCD monitor's back-light is faulty. Send it back to the supplier to have it fixed (they should not have reurned it to you in this condition).
If the other monitor also displays a bright pink background then the video card is faulty and needs to be replaced.
Nov 19, 2009 | Sharp Computers & Internet
My monitor's white balance is all out of whack!
your problem is the connection to your cpu connect it propely and make sure it is STRAIT if the problem persists contact me
Aug 17, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL11511
To even things out you need to use the controls on the monitor to lower the brightrnes. to acceptable levels. When playing a DVD there are seperate controls in the software and your graphics driver to adjust the Video Overly settings. Look for settings called gamma and brightness in the video overlay settings in the windows display properties panel. This should help even things out some. Deal is to crank down the brightness on the monitor and crank it up in the video settings in windows. It will make the DVD's brighter and rest of the time the regular screen darker.
Jun 26, 2007 | Acer AL1511 15" LCD Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
Acer AL1717 17" LCD Monitor Logo
54 people viewed this question
Ekse
Alun Cox
