Question about Nikon COOLPIX L18 Digital Camera
Broken lcd screen on Fujifilm Finepix z10fd - Nikon COOLPIX L18 Digital Camera
  • Mahendra Patel
    Mahendra Patel Dec 02, 2008
    The LCDscreen broke as camera was in my back pocket, can not see anything.
Lcd broken.Any chance to change lcd.
yes LCD's are a pain to replace on your own but luckily I'm here to help... please remember to rate me for helping you
the easiest way is to buy a new LCD
such as here:
finepix-f30-digital-camera-repairing-lcd-display-screen-replacement.html">http://www.ownta.com/fujifilm-finepix-f30-digital-camera-repairing-lcd-display-screen-replacement.html
or on ebay:
http://cgi.ebay.com/FUJIFILM-F40-REPLACEMENT-LCD-DISPLAY-REPAIR-PART_W0QQitemZ320283316623QQihZ011QQcategoryZ64352QQcmdZViewItem
Follow link to ebay vendor: Most lcd display screens are available
or you could build your own but without a ton of experience, this is more of a challenge than it's worth.
I hope this helps :)
Jan 04, 2011 | Fuji Cameras
Replacing LDC screen on Fuji Z10FD camera
Probably, yes.
Remove the 2 screws on the side,
Remove the 3 screws in the buttom. (2 of which are tri-wing)
Remove the 2 screws in the battery compartment.
Flip out the chrome side (from the front backwards)
Remove the 2 screws underneath the chrome side.
Turn the camera upside down. You can now flip the backcover down (gently lift the cover, both on the mid by the tripd hole and on the side, where the crome plate was) Watch out for the USB connector.
Gently lift the broken LCD out. You need to release (flip up) the tiny white lock on the connector to release the ribbon.
Assembly same procedure, but backwards.
Beware of the flash components. The can give a nasty electrical chock.
May 21, 2010 | Fuji FinePix Z10fd Digital Camera
Lcd screen
EBAY has lots of camera parts stores. Just search fujifilm s5600 lcd screen , or parts camera.
Aug 26, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Spider web screen..
yes lcd is broken. repair is usually around 120.
Jul 10, 2009 | Fuji FinePix Z10fd Digital Camera
Fuji z10fd no power after lcd replaced
I have repaired several of these. On most of them I found that one or both nano fuses on the main board have gone bad. They are labeled F2 and F3, they are 2 amp nano fuses. They are located on the back side of the main circuit board, near the top. Right at the top of the SD card socket. You will need to use a soldering iron, and desolder both Battery contacts. Also several wires on the main board will need to be desoldered, to get to the fuses. You should have some experience working with surface mount components and soldering before attempting the repair.
Feb 22, 2009 | Fuji FinePix Z10fd Digital Camera
Have found you an online PDF Version of the Z10FD Users manual you should get in the box !
you need adobe acrobat to be able to view this !
http://www.fujifilm.com/products/digital_cameras/z/finepix_z10fd/pdf/index/finepix_z10fd_manual_01.pdf
Hope this helps !
Oct 28, 2008 | Fuji FinePix F480 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
89 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
