Question about RCA HD52W59 HDTV Projection Television
HD52W59 Convergence Power Supply
I had a retired TV repairman diagnose my tv, said a transistor and two resistors blew on the convergence power supply board. I have the board in front of me, part number looks like PSDF-240. Can't find one on the internet. RCA says I have to have the TV diagnosed by an authorized repair center. Any ideas?
Thanks,
Tom
  • TomL321 Sep 09, 2008
    Thanks very much for the link... I couldn't find many out there, and that's the best price I've seen. One more question, though. It would much cheaper for me to just get my hands on the transistor and two resistors I need. The rest of the circuit is still good. But I only know them by the circuit board location codes TP630, DP631 and DP632. How could I find out the actual part numbers (or specs) not having access to the RCA drawings?
    Thanks again,
    Tom
  • RCA Master
  • 8,617 Answers
You can get the replacement ITC222 convergence power supply board at the following link. They have one at promotional sale price this week also under the sale items category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
No power fuse blew
it means you have shorted regulator transistor on power supply..
It is usually fit in heat sink..
Try to replace it and the fuse again also check any fusible resistor near that transistor..
Feb 23, 2012 | SNK Magnavox 32MF338B27 32 in. LCD TV
TOSHIBA 40G300U3 will not power on, chaged fuse when I plugged it in it blew
Good day!!!!
if the fuse blew continuously when you plug it...
that problem is cause of shorted parts on the power supply board...the regulator (transistor)..
or you can buy a new power supply board...
Jul 30, 2011 | Toshiba 40G300U TV
When adjusting the convergence, ended up with a concave screen, then it smoked. Is this a power supply, or worse? Is there any advice that you could give me on this...
Thats usually indicating the ICs have failed. Usually with that model its best to replace the board rather than try replacing the individual components as ther are several 3.9 ohm resistors that will need to be checked and possibly replaced along with both ICs. www.tvcircuitboards.com should have the replacement board for your model if you need one.
Jul 08, 2011 | Samsung HCL473W 47" Rear Projection...
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem on 60 inch rear projection RCA
i have a rca 52 inch projectin t.v and the power light turns on then off 3 times then it won't turn back on
Apr 22, 2008 | RCA P60828 TV
Convergence chips
The convergence IC or in a sense ,amplifiers and the resistor are output resistors... if they are burning up the current going through them is spiking too high... TO me this is an indication that the "convegence yokes" are shorted. These are coils around the tubes that control convergence. I would suspect maybe that these are shorted to ground somehow. This is my first guess for this problem
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
TV turns of automatically
could be noumerous things: 1. check power supply, too high or too low voultage may cause TV to shut down. measure it to detarmine if power supply is faulty. 2. check convergence board. If either of these 2 fuses on the convergence panel are open then replace the STK output devices PLUS check for any resistors in that circuit that may have overheated and changed value. Use actual fuse values, putting in a larger fuse, even to try and diagnose problem, will cause more severe damage. 3. Check for bad solder connects on the PC board in the area of the power cord and related components. good luck
Mar 26, 2006 | Sharp 27C-240 27" TV
Picture on screen wont stay on
Mar 26, 2006 | Sony KV-35S42 35" TV
RCA HD52W59 HDTV Projection Television Logo
724 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
