Whirlpool sport flashes F-33 - Washing Machines
    Genius:
  • 1,028 Answers
Ckd wiring from control bd to pump also ck pump to see if is running ..f33 means communication failure from pump to main control ..could even be bad control bd(most likely)
Posted on Sep 07, 2008
Hi I have a Whirlpool 10KG washer HDW1011W9. F 33 is flashing.Please can you help?
WHEN CONNECTING THE WATER HOSE DO YOU NEED TO PULL THE BUNG OUT FROM THE BACK OF THE MACHINE
Mar 27, 2011 | Whirlpool GHW9400 Front Load Washer
F 33
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa
Mar 04, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Fault code f-33 on a whirlpool duet.
The F33 code is a pump failure code. The control unit is not measuring the proper amp draw on the pump during pump out. Remove lower panel and unplug then replug in the pump 2 or 3 times to remove any corrosion. While your down there, take the front of the pump off to check for any blockages.BE SURE TO UNPLUG YOUR WASHER WHILE SERVICING!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an f/33 error message on my whirlpool duet washer how do i fix it
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 26, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
F-33
Hello there
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
2. Replace components if necessary.
Dec 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Grinding noise when washer starts some spin cycles, washer stoped and game my wife a f-33 reading. whirlpool told me to unplug(reset) the washer for 30 mins. i did this and the washer still has the...
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
Oct 11, 2008 | Whirlpool Washing Machines
I have a whirlpool sport and it is flashing F-33 at the end of the rinse cycle
Peace,
Try unplugging it for 10 minutes and see if it resets the system after you plug it back in!
The user guide may mention code descriptions!
Otherwise you may need hands on service !
ngafm
Please leave me a rating before you sign off!
Thank You
Sep 07, 2008 | Washing Machines
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
