Click start control panel-view devices and printers.
You should see your webcam from there.
If you have trouble with your webcam:
Click start control panel-administrative tools-computer management-device manager-scroll down image
devices you could see a yellow question mark ?
right click to reinstall drivers or update driver
xp.Click start right click on
computer select properties device manager scroll to image devices expand right
click to update driver in W7
http://download.cnet.com/2000-20_4.htmlon the home page you should
see a search tab just type in what you are looking for IE:
webcam name webcam driver you might have to try a few times to get it right
software if you don\'t have the driver you will need to download one here
rather doing a driver hunt, which can take hours.
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.htmlWindows XP/Vista/7/8
It might take some time being a freeware driver solution.
note: It will find all of your outdated drivers.
This is a
free driver solutions.
This will automatically search for and find the correct driver.
You will have to update every driver individually once you update. You might be
asked whether you want to restart or make a system restore. Point click no to both of these, then continue updating each driver free, then restart once all of the drivers have been updated.
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But it doesn\'t hurt to check if your
Java, Flash and
Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including
webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP:
DirectX 9.0c Windows Vista
: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computerIf you still have no webcam installed, Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device."
The "Add a device" window will open and Windows will search for devices connected to your system but not installed.
Click on the webcam name that shows in the search box and
then click "Next."
Choose whether you want Windows to search for the webcam
device driver using Windows Update over the Internet, or if you\'d prefer to
have the device manager search for the driver using a disc supplied by your
laptop manufacturer. Most drivers can be found on the system recovery disc
included with your laptop, if you choose to add the driver from the provided disc.
Place a check in the box next to your choice and then click "Next" to continue.
Wait while Windows searches from the driver using Windows
Update, if this was your choice.
An active Internet connection is required for Windows to
successfully do this. Allow the computer to install the driver and then reboot
the system for the webcam to become recognized by the system.
Otherwise, you can use the system recovery disc or a driver
downloaded directly from your laptop manufacturer to install the driver without
using the Windows Update search feature.
Open the CD/DVD-ROM drive and insert the system recovery
disc, or place the driver downloaded from the manufacturer in an easily
accessed file directory on your PC, such as on the desktop, or in your "My
Documents" folder.
Choose the option "Install the software automatically
(Recommended)" in the "Add a device" application, and press
"Next" to begin searching for your webcam driver.
The hardware wizard will search the system recovery disc and
install the driver automatically. Press "Finish" to close the wizard
and then reboot the computer to allow recognition of the webcam.
Choose the option "Install the software manually"
in order to browse to the driver location where you saved the driver and
install it from there.
Use the opened file manager and locate the driver.
Click the "Next" button to install the
driver, then reboot the computer to add webcam functionality.
