Question about RCA RS2663 Shelf System
No manual I cannot set the clock, and no directions come with it. Is there a clock? I push the button "clock" and the digits flash 12: 01but nothing changes the numbers.
  • 10,594 Answers
Follow the procedure to set time/ clock.
Setting the clock
1. Press and hold CLOCK until
the hour flashes on the display.
2. Press << / >> to set the hour
and then press CLOCK to shift
to minute digits.
3. Press << / >> to set the minute.
4. Press PROG•SET to save
settings or STOP to quit setting.
You can download user manual at RCA Support.
Regards,
Posted on Sep 07, 2008
How to set the clock on a MT01
To set the clock
1. Turn the key to "ON".
2. Push the "SELECT" button and
"RESET" button together for at
least two seconds.
3. When the hour digits start flashing,
push the "RESET" button to set the
hours.
4. Push the "SELECT" button, and
the minute digits will start flashing.
5. Push the "RESET" button to set
the minutes.
6. Push the "SELECT" button and
then release it to start the clock.
Oct 22, 2013 | Yamaha MT-01 Motorcycles
Lost manual for springfield color changing alarm clock model # 962032612V0706
I have one & I just set it. You hold down the s button until the time flashes then use the arrow buttons to set hour then push the s again to set minutes & when they flash you push the arrow button again then repeat with the alarm & date.
Tina:)
Jan 16, 2013 | Bon-Ton Springfield Color-Changing Desktop...
How do I adjust the time on a 2005 yamaha roadstar digital clock?
With the key on.......
1) Push the select button and reset button together for at least two seconds.
2) When the hour digits start flashing push the reset button to set the hours.
3) Push the select button and the minute digits will start flashing.
4) Push the reset button to set the minutes
5) Push the select button and release it to start the clock.
Dec 14, 2010 | 2005 Yamaha Road Star Midnight Silverado
How do you set the time, date, and alarm?
TIME: Depress the time button and hold until digits flash. Push the right arrow until the time shows the correct time.
DATE: Depress the date button and hold until date flashes. Push the right arrow until the digita display the correct date.
You can download the manual below:
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Please rate this reply if you found it helpful
Jul 02, 2010 | Timex T311T Clock Radio
Adjust the time clock on the 2005 xt660x please
G'Day Dutchgbg
Here is a quick guide to set the clock
1: Push the "select" button and the "reset" button together for at least two secounds.
2: When the hour digits start flashing, push the "reset" button to set the hours
3:Push the "select" button to fix the hours, and the minute digits will start flashing.
4: Push the "reset" button to set the minutes
5: Push the "select" button to fix the minutes, and then release it to start the clock.
regards robotek
Apr 09, 2010 | 2005 Yamaha XT 660 X
How do you set the clock on a 2006 royal star tour deluxe?
Select the clock (push the "select" button for at least 2 seconds).
Push both the "select" and "reset" buttons for at least two seconds.
When the "hours" digits begin flashing, push the "reset" button to set hours.
Push the "select" button, and the "minutes" digits will begin flashing; push the "reset" button to set minutes.
Push the "select" button to start the clock.
Mar 03, 2010 | 2006 Yamaha Royal Star Tour Deluxe
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
1985.5 PORSCHE 944 digital clock. I am trying to change the time on the digital Clock. This was never stated in the manual that came with the car. Any help is greatly appreciated Trey
hi , I hope this help you out. the digital clock of your porsche 944 late 85 is a chronometer also.
this digital clock has three buttons, lets call them A,B,C from left to Right.
to set the time press the B Button for 5 seconds. the digits should be flashing by that time.
It will show you the option of 12H or 24h Mode, press the A button to select what you want, after push the B button to select the Hours it should be blinking Press the A button to select your time. repeat step to set the minutes.when your done Push the C button.
By now your digital clock would be set. the chronometer is the C button. to switch between clock and chronometer push C button, if you select chronometer. the A button start and stop, the B button Reset. Good Luck
Can't set date
Download the user manual (P23-DH III) from here:
http://rapidshare.com/files/181603396/P23DHIII.PDF.html
Nov 15, 2008 | Canon P23-DH Calculator
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
RCA RS2663 Shelf System Logo
832 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
