Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Sony tv My tv wont stay on. The tv is only 5 years old. It will come on then 5 min goes off again. We turned it off for 4 hrs turned on it came on 5 min out again. Any thoughts n this?
  • amyabt Sep 08, 2008
    My television was doing the same thing. Mine is only 4 years old. Now it won't come on at all.
  • Ronnie Dec 13, 2012
    My Sony is doing the same thing, I bought it in 2007
    Problem Solver:
  • 39 Answers
Check solder joints in horizontal deflection circuit.
Posted on Oct 02, 2008
Tv wont boot up
This is a prime case of bad capacitors in power supply. You may have only had it a year but how old are the parts that are in it?
Oct 30, 2017 | Televison & Video
My 17 yr old sony triniton goes on after about 5 or so min. the picture is great then the screen goes black (audio fine) for about 4 seconds then the pic is back for about five min then the same thing...
U have a soldering iron,a roll of solder and can do a basic soldering work too?Yes,take the tv aparts.Tv have a cold sodering video board,that the board where it is connected to the CRT-(tv tube).Resoldering the sock pins of the video board that connected to the tv CRT-(tv tube).The tv picture,will be stable and work again as soldering work it is done and the tv have to a good connections between the tv video board and connected to the CRT-(tv tube) again.
May 24, 2011 | Sony Televison & Video
Every so often ithe screen just goes blank and you can't change channels or input devices when it does this. There are no blinking lights or no codes being shown, the green power indicator light stays...
It sounds lamp is reaching to end of its working life and causing that problem due to its weak result.
Replace lamp in tv to solve this issue. Lamp replacement procedure is easy and written in user manual of tv, please buy Sony original lamp for good picture in tv.
Thanks.
Feb 01, 2011 | Sony KDF-E502000 50" HDTV
TV stays on for few mins and then turns off
IF its the lamp for Lcd. Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Part # is xl-2200 found it here: http://www.discount-merchant.com/SearchResults.asp?Search=XL2200+?Click=48173 God bless you!
Nov 17, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
OVERHEATED?
yes open it up get dust out run small fans in nit see how long it stays on
Sep 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
TV will not turn on
can you respond to this same post and let me know if it blinks 3 times or what the number of blinks is and I will try to assist you.
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Jan 18, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Powers off by itself.
Power supply or sweep suppys have parts that are overheating and breaking down or cold solder connections. Call someone who knows this set like the local authorized magnavox/Phillips dealer/servicer. Good Luck
Aug 04, 2006 | Philips 60P8341 60" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
