Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Green status light keeps blinking after lamp replacement
After replacing the lamp in my Mitsubishi WD 52525 52 inch DLP television the green status light keeps blinking rapidly. I have pressed the reset numerous times, holding from 10 to 30 seconds. Unplugging the set for 30 to 120 seconds. I have removed and replaced the lamp assembly. I also cleaned the filter, the fan switch seems to be functioning as is the lamp compartment switch.
  • 1 more comment
  • Bernie Cieslar
    Bernie Cieslar Sep 21, 2008
    unfortunately I didnt mention that the caps were already changed out. i have since sent the format board in to be checked out...i should know this week if that is the problem.
  • apositive1 Jan 29, 2009
    Same problem. After replacing the bulb, the green light would blink really fast and sometimes stay off for about 2 seconds. I remember reading somewhere that it can be tricky to get the electrical plug from the TV to plug into the lamp housing correctly/completely when reinstalling the lamp assembly. I completely removed the lamp assembly and reassembled the TV just to see what the symptoms would be. Same result with no lamp; fast blinking light with maybe 2 sec. pause and sometimes the speakers would pop very faintly. I think the bulb assembly isn't plugging in all the way. There is plenty of slop on the TV side of this electrical plug. Good Luck and thanks!
  • Anonymous Mar 28, 2014
    I replaced bulb thinking that was problem but it did not do it. I removed rear cover and seen fan was caked with dust so I removed fan cover and fins were completely clogged up. After cleaning what should I do next?
  • Mitsubishi Master
  • 8,617 Answers
Continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Mitsubishi wd-73c9 status light blinking orange won't turn on
may need the lamp replaced pt# 915B403001
Recommend Phillips, OSRAM or Mitsubishi original (as from experience others will not work or will have very short life)
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73C9
Mar 08, 2015 | Mitsubishi WD-73C9 73" DLP TV
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi 73 inch. green light blinks for a few seconds then the status light stays on. can hear a clicking noise when the green light is blinking. Replaced the lamp and that does not fix anything.
Mits has had an excessive number of problems with color wheels in some of their optical engines. Provided you replaced the lamp with OEM parts I would suspect the color wheel is causing the noise as well as the shutdown issues.
Bill W
integrityhomeworx.com
Mar 14, 2011 | Mitsubishi WD-73736 Television
Mitsubishi DLP TV model WD-65100. Power not ON
What about Lamp Fan if it is defective lamp will not turn on and if Ballast Board is not working then Lamp itself will not power on. Encompass has parts for this TV 1-800-638-3328
Feb 09, 2010 | Televison & Video
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,025 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
