Question about Philips Magnavox DVD/VCR Dual Player
Can't get my phillips dvd/vcr recorder to finalize dvd. How do I do it.
  • 2 more comments
  • japarker Oct 30, 2008
    DVD will copy from VCR (Dubbing) but can not get to Edit in setup to Finalize the DVD.
  • Anonymous Nov 23, 2008
    i have the same problem unable to finalise disc
  • eastmans Dec 02, 2008
    my phillips dvd/hdd recorder was allowing me to finalize then doesnt allow any more.
  • Molly Wray Jan 04, 2009
    I did 8 transfers of vhs to dvd with my phillips and they all finalized fine.
    I'm now stick. I try to finalize but don't think anything has been recorded
    in the disc in the first place, and that's why it won't finalize. The record button is lit and it says I'm recording but I don't know if it really is. When I put the disc in my computer or put it into the player, it identifies it as a
    blank disc...even though it went through a 2+hour recording process with the red record light on the whole time.
Here is the tec line phone number 1-800-PHILIPS (744-5477).
if you call the tec line they will ask Model and Serial Numbers and when you bought it
but this is what i found out:
take the disc out,
put it back in and let it load to disc menu screen then press STOP,
no press SETUP button on remote and got to "Disc Edit"
then select "Finalize" and verify "Yes"
it will take a few mins. to finalize
This worked for me!
Posted on May 17, 2009
  • firebird-r Sep 25, 2010
    My Phillips works by following steps. Almost same as original comment.
    1) put dvd on tray
    2) close tray
    player loading disc menu
    3) press "STOP" button on your remote
    get blue screen on TV
    4) press "SETUP" button on your remote
    5) select menu "Disc edit" fom screen using button on remote
    6) select "Finalize" from screen
    7) select "Yes" from screen
    Wait while to get finalized.
5 Suggested Answers
  • 4472 Answers
SOURCE: I can't locate my owners
There you go that should be the manual you are looking for. If so I would hope you would take a second and rate this FixYa.
Thanks and Enjoy,
Posted on Jun 29, 2008
SOURCE: LG DVD/VCR Recorder Combo RC195 will not finalize DVD after dubbing
how can you finalize a disk
Posted on Aug 30, 2008
  • 8596 Answers
SOURCE: Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
Posted on Feb 15, 2009
  • 5306 Answers
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Posted on Jul 09, 2010
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox DVD/VCR Recorder ZV457MG9 How do I finalize my DVD on this player/recorder? is how to finalize a disk on Magnovoz! I have the ZV457MG9 - its model takes with
1) loading disk
2) select the set up button
3) select DVD edit
4) select finalize DVD
Then you finalize the DVD!!!
Jan 31, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
We have a vcr/dvd, model dvp620vr/07, we are having probs recording our pics onto a dvd and having the recorder play it, our computer will, why not the vcr/dvd recorder, what kind of disc do we need to...
What program or software are you using to make the DVD? The DVD must be "finalized" before it can be read on an external device, such as a VCR/DVD player. PC's however, can handle the un-finalized (is that a word?) discs because it assumes you may want to add more files (pictures). Once the disc is finalized, no more files can be added to it.
Dec 31, 2009 | Philips Phillips 16X External DVD 2XRW...
Finalize DVD
I have a dvd recorder with vcr it is a model # zv427mg9 we have lost our manual and do not know how to finalize the disc. We have transferred video from vcr to dvd and can't figure out how to finalize, please help?
Dec 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here: Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Playing recorded DVDs on PC or other DVD player
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Aug 23, 2008 | Philips DVDR3455H/37B
Recordings from your DVD recorder should play on other DVD players as long as you finalize the recording on your recorder.
A PC should recognise an un-finalized, but only in a DVD writer drive.
There is a firmware upgrade available for this model. Follow this link and select your particular country version DVDR3320/XX||type=CONSUMER||locale=gb_en||mode=prod_text||item=dvdr3320v||page=1||show=50&xsl=search_result.xsl
Select Software & Drivers and click on the link to the zip file.
Follow the on-screen instructions.
Mar 02, 2008 | Philips DVDR3320 DVD Recorder/VCR
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
Jan 29, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Finalizing DVDs of a previous burner
Neither will work. you will have to try a computer.
Oct 28, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Hooking up (properly) a vcr to dvd recorder and recording
could be cause there is a copy write protect on the vhs
Sep 02, 2007 | Ricoh (5125a) DVD±RW Burner
Philips Magnavox DVD/VCR Dual Player Logo
933 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
