Question about Whirlpool Dryers
Wire burnt out on connection to the heater - Whirlpool Dryers
  • 70 Answers
Replace the terminal. :)
Posted on Sep 07, 2008
Blk terminal and plug burnt off Heater relay main PCB
Even if it wasn't a poor connection made during the assembly of the wire harness, it could've loosened up over time as your dryer was used being that when the clothes spin the inertia causes shifting of different things inside the dryer. How long did the dryer run before this happened?
Also gas dryers always have a fuse in them, I'd check that before you put it all back together too because chances are that if you have a burnt wire the fuse probably went too. The fuse is usually white, about an inch long and has to male end terminals on it.
Mar 18, 2013 | Samsung DV330AEW Dryer
I have a burning smell in my dryer. it heats up and runs but the clothes have a burnt smell
Do not switch on the dyer unless this is checked out as the fault seems related to the coil heating some insulation or foreign particles when it is switched ON.
Sometimes this can be due to wires buring after coming into contact with the heater, the insulation being burnt out.
Also if the connection leads on the heater is bad then the JOINTS might heat more and thus burn the wires or any other materials that come in touch.
An inspection / with a good obserrvation lamp is most important.You can also start by observing the leads on the heaters.
Aug 18, 2011 | Kenmore 76972 Dryer
My 1988 washer/dryer combo Model LSG1000 is showing an E9 code for the dryer. Do you know what that means?
The "E9E" code means Low Voltage is seen at the Control Board. Make sure the RED wire on the Control Board that connects to the Heater Relay is not loose or burnt. This is the LINE ONE voltage supply to the Control Board and if it has a bad, loose or burnt connection it will cause E9E to display. If there are no loose of burnt wire connections then the control board will likely need to be removed and replaced.
Aug 16, 2011 | Maytag Dryers
Polohunt1@aol.com my bionaire bch9221 120 volt heater does not produce heat anymore.....i'm thinking that maybe an element within the unit is burned out.
Mine was doing the same thing. Took it apart and found that the white wire which hooked up from the circuit board to the heating element had burnt which broke the connection...hence no heat....replaced burnt wire and resoldered to heating element...put it back together and voila I have heat once more....still doesn't solve why the wire fried though....
Oct 13, 2010 | Bionaire Heating & Cooling
How does the reset work? I am helping a friend troubleshoot his water heater. One of the wires that connected the pig tail to the power block fried inside the water heater cover. I decided to remove the...
The reset button is set up to open the circuit if excess current is drawn by a failed Element. It works by getting hot and switching off due to current above its rating. The burnt wiring more llikely happened over a period of time because of a resistive joint in the block getting hot due to the high current that water heaters consume. It seems that the element has failed if the reset button does not get the system working.
Sep 17, 2010 | Rheem 81VP15S Point-of-Use Electric Water...
KW9B model, power to unit but no heat when timer
Heaters are pretty simple: when timer is on, voltage is applied to the heater elements until timer turns off. To troubleshoot your problem, use a multimeter or circuit tester to check the terminal connections on the heating elements themselves. With the timer ON, you should be able to read voltage (120 or 240, depending on your heater) at those connections. If you don't check the continuity of the wiring from your timer to your heater. Continuity w/out voltage at the element indicates a faulty timer, no continuity means bad wiring. If you do read voltage at the element but it isn't heating, your element is burnt out -- time to replace it. If it's a newly assembled setup or seems odd to be burnt out for some other reason, double check that you're using the correct voltage for that particular heater... 120vac won't run a heater rated at 240vac.
Feb 04, 2010 | Saunacore Standard Residential Sauna...
Dimplex XT24 Series E. Burnt/melted live feed wire.
Same problem i had on the XT24, found out that it was the thermostat shorting out the circuit, changed thermostat and worked ok.
Dec 05, 2009 | Heating & Cooling
Dryer heater stops working
BAD AIR FLOW CAUSED BY VENTING IN THE HOUSE BEING PLUGGED
Aug 11, 2009 | Amana Dryers
Heater fan won't work. had motor checked, it is good
it could be two things that i can think of.
first and easiest to check is there is a 2 wire connector at the lower corner of the interior fuse box. sometimes it gets burnt because of poor connection. turn the blower on and wiggle the wires when you find them the are fairly large wires.
i think one is red.
other than that the blower resistors go bad but the normally work on high. the blower swith could be burnt?
Jan 27, 2009 | 1999 Ford Contour
Heater won't come on
its difficult to make a homeowner an expert in troubleshooting his/her equipment if he/she has no technical background - but - I will try. First check the cord to plug connection. Is it tight? Does it look melted? Next, take the unit apart where the cord goes into the unit. Check the wiring path. Look at each connection. Look for burnt off wires at connections. Most connectors are the push on type and are mechanically fastened to the wires. if they are burned off you'll need replacement spade terminals and a crimping tool. (radio shack) has these. one wire will go through a thermostat and out to an element terminal. one wire may go through a thermodisc overload, then to the thermostat and then to the element. the other wire will definitely go straight to the element. there may be some extra connections for lights etc. if you have to take apart the heater make a diagram of which wires go where. use some masking tape with numbers written on it to make sure the wires go back to the same place you took them off.
Nov 28, 2007 | Honeywell HZ519 Baseboard Heater
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
