Question about Kenmore Elite 45986 Front Load Washer
Kenmore front loader washer
My front loader does not have any lights and wont start. The last load ran didn't seem to spin as well as usual. I unplugged it and plugged it back in. I checked to see if the outlet was live so the washer seems to be getting power. This happened once before but I dont know what I did to reset things. Any advice would be appreciated.
L.Pearson
  • 4 more comments
  • Oznob Sep 07, 2008
    That is exactly what happened to me today on the same washer??? What's up?? Does it have something programmed in it to do that on Sept 7, 2008? Please help?
  • Anonymous Jan 06, 2009
    exactly to me too. any soln yet?
  • phand01 Jan 06, 2009
    same to me. power won't turn on, no light either, and then flashing f71.
  • onfire4jeez Jan 29, 2009
    What was the outcome of this? I am having the same problem and am not sure whether I need an electrician or an appliance repair person.
  • Anonymous May 14, 2009
    lights flash and it wont turn on
  • roger4au May 15, 2009
    My Kemore h3 won't turn on but it does have lights. It gives me error code DLF. I presume that it means door lock failure.
    Novelist:
  • 166 Answers
Peace,
You need hands on service !
ngafm
Please leave me a rating before you sign off!
Thank You
Posted on Sep 07, 2008
Kenmore 90top loader,wont spin or pumpwater all out just makes a loud grinding noise,,
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Feb 18, 2010 | Kenmore 24032\24036 Top Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Out of balance washing machine
yea these things are a mother to get level. And if you get them right, a wood floor will settle under there heavy wieght. I found that after the third releveling . The last time i set all the screw adjusting feet to 35 inch pounds after initial truing. It has been good now for 18 months. One more thing, they have cast ceramic "frames" around the nylon drum that wont take too much abuse. Be sure its level before you cause serious damage.
Jun 04, 2009 | Kenmore 46462 Front Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front load washer that's noisy when it spins
on most kenmore front loader after some time the bearing start to wear and the washer will get louder and louder,it is a big repair job!-mike
Mar 23, 2009 | Kenmore HE2 Plus Front Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
266 people viewed this question
Sal De
fordexpert
Robert Rankin
