Question about GE Washing Machines
Waher is not draning. where do i find the pump filter?
  • 70 Answers
You will probably find it not the filter thats blocked and you will need to remove the pump and take the obstruction out. :)
Posted on Sep 07, 2008
Water not draning
If kitchen side drains are clear then there might be some blockage in the pump system. Check the drain pump is working during drain cycle. If you can hear the pump but the water does not go away then you need to check filters at base of dishwasher. Beyond that you will have to open the pump assembly to look for debris.
see these instructions which might be helpful.
http://jdesbonnet.blogspot.com.au/2010/11/hotpoint-aquarius-fdw60-drain-pump.html
Apr 04, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Tip
How to get your washer to work when it does not spin or drane
go to the fillter at the front of the mashine and turn it to open, make sure mashine is turned off.put a bowl or plenty of towels down let the water drane out then clean the filter out.put it back in close it and away you go
on Feb 16, 2010 | Washing Machines
LG washer
water is not draning open the drain filter and check if something is stuck on the pump if if fails replace the drain pump.
Jan 18, 2013 | LG Washing Machines
MY WASHER WILL NOT OPEN THE LOCK SYMPOL IS ON
Try a spin/drain cycle once or twice, then try again to open the door. Clean the filter and pump drain
May 01, 2012 | Washing Machines
Where is the pump filter located and need instructions to take apart to clean it out
it is located behind the waher where both hoses meet you have to take them off at the back of the machine and it should be right at that spot where the hoses were taken off. it looks just like the screen for a faucet in your sink.
Jan 01, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a AWM 500 washer and it says E4 i have lost the manual for it i think its the drain pump and want to know if u can get a replacement part
Most F/l wahers have a pump MOTOR which can be replaced with a generic. The motor can be removed from the pump body and replaced. Check with a laundry equipment outlet. Use a marker to show alignment before disassembly. Check that the pump filter is not blocked first..Good luck...Nomess
Apr 22, 2010 | Washing Machines
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Please rate my solution.
Thanks.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Error f05
Check that water is draining out o/k and that the outlet hose is not kinked or restricted.
Make sure pump is o/k.
if it has a removable filter at the front, then remove and clean.
If no exterior filter, then remove rear panel of waher, locate pump at bottom right of m/c. undo the clip that secures the large black hose to the bottom of tub, and remove the hose.
Remove and clean plastic filter inside the hose.
Refit and make sure the hose is on properly, test for leaks.
Hopefully, this will solve the prob.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint Washing Machines
Need to find the filter as drum not spinning and water leaking
The filter on this model is in the main hose leading from drum to pump. It can be accessed by removing the panel at back of machine.
Dec 13, 2008 | Hotpoint Ultima WD72 Front Load...
Dishwasher dose not drane
YOU CAN TRY REMOVING THE LOWER RACK AND LIFT OFF THE SPRAYER. THE DRAINAGE WHOLE IS USUALLY VISABLE. YOU CAN FLUSH OUT THE DRAIN TO SEE IF THAT DOES IT. THERE SHOULD BE NO STANDING WATER IN THE BOTTOM OF YOUR DISH WASHER AFTER WASH CYCLE AND DRY CYCLE. HOPE I COULD HELP.
May 02, 2007 | Hotpoint 24 in. DF55 Free-standing...
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
