Question about 3G Technology GM-171B 17" Flat Panel LCD Monitor
Monitor temporarily on
My monitor temporarily turns on (less than a second) when I boot my PC. After that the green power light is on indicating power and a good connection, but my screen is blank. What could be wrong?
    Novelist:
    Scholar:
  • 128 Answers
Hi, It looks like it may be receiving power from the computer but not a signal. Try a different monitor cable from the PC and even a different monitor. If doesn?t work, it could be the graphics card in the PC. Daniel
Posted on Feb 16, 2006
When i turn on my computer/hard drive, the green light turns on for about a second and then it turns into a flashing red light and also the fans stop working/turning. Nothing comes up on the monitor.
It sounds like the power supply is failing. This computer has an odd size power supply. You could try another power supply from another computer and see if it boots up just connect it from the outside of the case temporarily . If it is the power supply you could remove the power supply to measure it and search online for the correct one. I just did a Google search and there were alot of option to choose.
Thanks for using FixYa
May 30, 2011 | HP Compaq dc5000 PC Desktop
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
When i turn it on it only appears only a second , my monitor turn black
Hello Chelleydiao, hi, its either you have a CPU problem or the monitor itself. Check or use another monitor to see if the problem is fix. you see an blank monitor can also be caused by the CPU if it fails to boot. the aid the checking, do you see any orange light on the monitor? or any indication.... the led light on the screen in summary: green or blue means there is power and the CPU boots up. if orange the CPU fails to boot, if there are no lights on the Monitor panels, there are problems on the monitor. check these first....I need a much detail description.
Dec 18, 2010 | AOC Monitor
Dell 8200 green power lite comes on green hard drive lite off
Check your fans o see if they are running and if the PC isn't getting too hot because that will cause it to stop and not boot up.
Dec 29, 2009 | Dell Dimension 8200 PC Desktop
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Dell inspiron b130 won't boot up.
Connect an external monitor to the laptop and see if you can see what is happening on that.
It is a possibility that your inverter is faulty and will need to be replaced. They will normally power on for a few seconds, then cut out.
Remember to set the laptop to use the external monitor with the function keys.
Apr 09, 2008 | Dell Inspiron B130 Notebook
Monitor is on when computer boots up , then turns off
You can email rhartze@key-services.com and provide your telephone number... he will call you to assist.
Dec 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Startup issue
Sounds like a problem in the power supply section that will need component-level electronic troubleshooting. If it's under warranty and less than 30-60 days, I would suggest an exchange. If not, I would call the number in the manual for help.
Jan 01, 2007 | Apple Cinema HD 30" LCD Monitor
3G Technology GM-171B 17" Flat Panel LCD Monitor Logo
152 people viewed this question
Top 3G Technology Computers & Internet Experts
William Miller
William Miller
Chris Larocque
Daniel Quinn
Daniel Quinn
Are you a 3G Technology Computer and Internet Expert? Answer questions, earn points and help others
