Question about Philips Magnavox 51MP392H Rear Projection Television
Popping, snapping sound
My set was still under warranty when it started snapping and popping, particularlly when watching hdtv. I've had someone out 3 times to look at it, but to no avail. I had two of the three boards in it replaced, but a month or two ago, it started popping again. If I turn the volume down to zero, the popping stops. Any ideas???
    Genius:
  • 1,139 Answers
Hello fulby2001,
Have the CRTs checked for grid to cathode shorts. The CRTs do this (pop and crack) when they have Grid Cathode shorts. I would advise having a qualified TV technician do this for you.
Thank you,
I hop this helps
Shuttle83
Posted on Sep 14, 2008
The tv menu screen keeps popping on and off when watching TV. Sometimes the sound volume control screen will appear but you cannot control the volume. The set is only 4 months old.
It should be under warranty still but if not and menu comes up on its own I would suspect a problem with the keyboard where the buttons are---they may look and feel fine but they usually are the cause of this kind of problem----In several cases I have had to remove individual micro switches under the buttons to confirm or deny this---if for example menu is disabled by removal of that switch (not the plastic button but the switch under it) then the set can be operated with the remote-----I would see about getting it fixed/replaced even if just out of warranty.
Oct 29, 2012 | RCA 32" LED HDTV LED32B30RQ - ON Corp US,...
Can i change my watche ?
it is still under warranty
contact the ,manufacturer customer service and ask how to get a refund for the faulty item under warranty
Jul 10, 2017 | Omega SeaMaster Watches
While watching the T.V. I started experiencing a random of two to ten second very loud static, popping sounds then it would go to a green then a digit scene then a gray w/loud sounds the popping sounds the...
Your set has a problem with its power supply. If it is under warranty, have it replaced ASAP. If your warranty has expired, you can take the set to any good repair shop - ask for an estimate before having any work done to it.
Feb 19, 2011 | Element Electronics FLX3711B 37 in. LCD TV
Individual pixels are turning on ramdomly. No real picture. No sound. There was a snap when this happened
Sounds like something on one of the boards went. You heard a snap. May have been a capicitor that popped. If it is still under warranty, take it in and have it replaced. If not, depending upon your abilities you may want to take it to a tv repair place or fix it yourself.
Aug 04, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
I have a SONY WEGA flat screen, last night while watching tv, there was a loud pop in the tv, now the LAMP light keeps flashing and there is a grinding sound coming from in the set. No Picture, no other...
The loud pop was a capacitor blowing.
The light is flashing because either power board or ballast board is faulty.
Using the TV in this conditions can cause further damage.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 04, 2009 | Sony WEGA KDL-42XBR950 42 in. LCD HDTV
42 in LG red dot like static on my screen still able to watch
Hi there. I don't know if you've already solved this issue, but If it's only 3 months old, contact LG Technical for Service/Repair as it will still be under warranty. It sounds like a hardware fault and would be better for you to get it done for free rather than have someone mess around with it.
Hope you have sorted it
Tim
Nov 26, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Tv cuts itself off after about 2-3 minutes
try unplugging it to reset it 7 call the manufacturer. is it under warranty, do you have a dct?
Apr 21, 2008 | Televison & Video
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
Sound Problems
this set has a int/ext switch on back..and audio ic inside
Sep 11, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips Magnavox 51MP392H Rear Projection Television Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
