Question about Sharp AR-5320 Black and White Copier
Sharp AR507 Oaccasionally the copier will power on but will turn off after awhile and will not turn on again until it sits for a day. Auto shut down is set for no shut down.
İS BEATIFULL
Posted on Sep 08, 2008
Only One Doc/Job Prints
When multiple docs/jobs are placed in the print queue, the printer becomes all confused and doesn't know how to prioritize. The solution is to dump the existing queue (usually by shutting down the printer and even disconnecting power) then queue up one or two jobs at a time to help the printer cope. This should keep Ground Hog Day at bay - at least for awhile :-)
Jan 02, 2014 | Lexmark Pro901 All-In-One Inkjet Printer
When I turn on my 42" vizio all I get is the vizio screen no sound and the remote will not work to turn it off.after being unplugged for awhile (days) i tried it again and it worked fine until i shut
You will need to get a diagnosis done on the set. It could be a power supply issue or a main board issue. Your problem is between one of those two boards.
Apr 04, 2013 | Vizio VW42LF 42 in. LCD HDTV
Savin copier shuts down on it's own and will not restart until it sits awhile.
Hello!
On my opinion you should call a Tech. It could be same broken transistor in the Power Supply Unit.
Sep 08, 2011 | Savin Office Equipment & Supplies
I was downloading music and my laptop turned off t now says arclibrary update: sorting files... it has been like that for two days what should i do
1. Try ctrl-alt-delete 2. Try "esc" 3. Do a force quit by pressing and holding the power button until it shuts down. Wait awhile and then power up again.
Jan 17, 2011 | Cameras
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Intermittant H-4 Problem: Turn copier on, works for a few days, turn off for awhile; then turn back on and it gives H4 code. Have several doing this, not sure how to fix problem, as resetting it goes right...
H4 is a heater/fuser problem. You may have a defective thermostat. Try to replace with a new one and observed if the problem will not occur again.
Nov 02, 2009 | Sharp AL 1631 Copier
I need document feeder tray & document feeder unit for Sharp AR507
The RSPF (Reversing Single Page Feed) document feeder unit doesn't have a single part designation for ordering the entire unit. It's a standard item with the AR507 (meaning it's considered a part of the full machine).
If you want to order individual parts of the document feeder, you can contact Sharp via their website.
Sep 15, 2009 | Sharp Office Equipment & Supplies
I power on tv and it shuts down after few seconds
There is a high voltage leak here, the reason it closes down is the protection mechanism isw trying to prevent more damage. better to turn it off and have it repaired before it catches fire or blows all the boards and becomes totally useless or beyond repair.
Sorry this isnt what you wanted hear but there is a safeyty factor involved here.
Please rate our help to keep the FREE service online ++++
Aug 31, 2009 | Mitsubishi WS-55807 TV
Sharp LC-30HV4U
I have the same problem with Sharp LC45GD4U intermittant turn off by itself ,somedays working OK..
Thanks.
Tanvo
Aug 26, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Firmware upgrade
What version do you have now?
Here is the newest version posted on SharpNet:
Version H2.40 contains the following modifications: 1. H5-01 error detection changed from 3 successive errors to 5. (POD1) 2. “H3” errors eliminated when ICU detects E7-00 error.(PCU processing change) 3. Image rotate information retained during paper-out condition by specifying use of manual feed tray. 4. If L3-00 or L1-00 errors occur after upgrade, TC 26-59 settings must be changed. Refer to technical bulletin AR-337-001 R for instructions. AR507.EXE Contains all the files needed to upgrade the AR287/AR337 copiers using a PC, SCSI adapter, and 7 series Black & White Imager. (AR287 ~ AR507) Refer to Technical Bulletin AR-505-001. AR507.EXE contains the following files – ICU_H2_40.mot, ICU_H2_40.fd, PCU_H2_40.mot, PCU_H2_40.fd, OPE_H2_40.mot, OPE_H2_40.fd, and Flash5.1.exe
The firmware upgrade on these "toner bombs" is no walk in the park but I can walk you through it and provide the bin files and software. contact me at double-u double-udouble-u dot brianbell dot net for more information.
Dec 26, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
