Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Same tv standby light blinks six times then stops and then repeats. HELP
  • morr1003 May 11, 2010
    my 34in sony wega trinitron turns on then clicks off then i turn it back on and its fine all day and night
  • 10,594 Answers
6 times blinks shows problem can be in following areas.
• +5 line is overloaded. (AY, BY, MY
Boards)
• +5 line is shorted. (AY, BY, MY Boards.)
• IC504 is faulty. (AY Board)
If you are tech-person, then understand easily.
Posted on Sep 07, 2008
4 Suggested Answers
  • 236 Answers
SOURCE: Sony blinking standby light
This is Sony's way of telling you that there is a short in you set.Probably the horizontal deflection circuit.(Horizontal output transistor shorted??). Also any other short. You need to take it to a techincian and have it checked out. It would be wise to get an estimate! Stargazer
Posted on Feb 12, 2007
BMW Rider
  • 232 Answers
SOURCE: kv-34hs510 standby light blinks six times over and over
Doorman45, common failure for your model, replace both IC`s with the following number stamped on the top of the IC,
MCZ3001D, the new & improved version ends in DB but I have installed the originals several times with no call backs, good luck
Posted on Nov 27, 2007
funkyjacob
  • 76 Answers
SOURCE: No Picture or sound, red standby light blinks six times
Sorry for how long it is but you should be able to find what is wrong in this guide
If you have any questions please dont hesitate to ask
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is 0 corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen. Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on Dec 03, 2008
Standby light blinks 6 times stops a repeats blinking
What is the brand name to your TV? These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 26, 2014 | Televison & Video
My sony wega blinks the standby light red 6 times, pauses and repeats. Cant get a picture on it at all. Any ideas?
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Sep 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    No picture or sound. standby light on front panel
    The light is blinking a repeating error code. Try to determine the number of blinks before a slight pause as that will be an error code. Then respond to this same post and I will assist you with diagnosing what may be causing the set not to power up.
    Dec 11, 2009 | Sony KP-46WT500 46" Rear Projection...
    Sony wega tv won't turn on. The standby light blinks six times..
    sorry, 6 blinks is a bad board!!!will cost around 1000 bucks,just by a new set
    Oct 09, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    Standby light stays on
    When attempting to turn on the set, the standby light should blink for a a while then stop once the picture comes on. If a problem is detected internally, the standby light should blink in a repeated pattern. Please count the number of blinks that are repeating and we should be able to help.
    Thanks,
    Dan
    Aug 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    codes.
    horizontal fault.
    stick.
    Oct 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    Six (6) blinks on the Timer/Standby led
    6 blinks means lamp thermal fuse blowing, replace thermal fuse.
    See here
    Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
    Sony Grand WEGA KDF-55E2000
    in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
    Jul 10, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
    Standby light blinks for 6 times
    Did you get this solved yet? Six blinks usuall meand thermal fuse. I can look it up if you still need help.
    Apr 08, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
    Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
    160 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
