Question about Compaq Presario 5000 PC Desktop
SYSTEM RECOVERY DISK DOES NOT BOOT I GET MESSAGE THAT I DO NOT HAVE OPERATING SYSTEM
    Scholar:
  • 133 Answers
You will have to enter the BIOS menu of your computer and change the order of boot sequence of the drives on your computer.
Posted on Sep 08, 2008
Problem getting recovery disk
I understand that you want to reinstall the Operating System on the computer. Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer. To start the system recovery:
  1. Restart the computer
  2. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. When prompted with a boot screen, hit the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the operating system.
If the ability to reinstall from the previous method is not available or fails during the recovery, recovery of the operating system will need to be from Recovery Media.
  1. Insert the disk labeled System CD into the computer's disk drive and restart the computer.
  2. When the eMachines logo appears on the screen, press the F12 key repeatedly.
  3. Select either CDROM or DVD as the boot device, this may vary depending on the system.
  4. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
  5. Note: If there are multiple Recovery CDs, please insert the first Recovery CD.
  6. After the system recovery program has loaded follow the prompts to reinstall the operating system.
Refer the URL for more information and for the link to order the Recovery media if required.
Nov 15, 2013 | eMachines T Computers & Internet
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
Sony laptop model# pcg-8112L. if press on power bottom. laptop screen come on. but laptop not start up. screen only show ing on a message" operated system not found". that " s message...
Boot into bios to verify system can see the hard drive. If system shows drive in bios and you are using windows xp or later try using the recovery console options by tapping F8 repeatedly to enter menu. , if you have one. If no recovery console...use either the recovery disks created by the system administrator or the original install disk to attempt a repair option on the boot of windows.
Your hard drive might have damage or the OS my be missing or corrupt.......you might have to re-install the system.
May 24, 2011 | Computers & Internet
Error message "load needed dlls for kernel"
1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue. 2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key. 3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console. 4. Select the operating system you wish to fix, and then enter the administrator password. 5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file. 7. Type exit to reboot the computer.
Mar 05, 2011 | Acer Computers & Internet
I power up the computer and get ''operating system not found'' on the screen.
The operating system not found error message is one commonly seen by techs and non-technical people alike. If you run into one, it may not be a problem at all. Here's an example:
If you're installing a new operating system to a hard drive or partition, or have just installed a new mother board, chances are you aren't alone. Most of the occurrences of the operating system not found error occur during these processes. In many cases, this is simply BIOS related, and can be changed very quickly (and remedied) during the Boot process. There are a wide variety of occurrences of this error, so if you have recently been "tinkering" or have installed a new operating system, take heart, there are many computer forums on the subject which may be able to point you to an answer.
Another reason why you may get an operating system not found message, is due to a damaged or incorrectly formatted partition. If your computer can't read the partition, then all data stored within that partition cannot be found. This includes your operating system. To solve the problem, you may need to look into partition recovery.
There are instances, however, when the operating system not found error occurs because of file system error, or worse, hard disk drive failure. If this is the case, you may require professional hard disk drive recovery, especially if you were not changing the system details recently, and were just working as normal.
When To Suspect Hard Disk Drive Failure Certainly, there is an explanation for everything, and the operating system not found error can be explained very easily. First, check your floppy disk drive. Is there a disk in it? In cases where this occurs, simply removing the floppy disk will likely solve your problem. Your computer may have been looking for an operating system on the floppy, and as a result, you were handed an error message. Removing the floppy disk should fix your issue.
If there is no floppy disk in your drive, it may be time to check the boot sequence. You can do this in your BIOS. First of all, does your hard drive get detected as the primary hard drive? If it does not, your hard drive may have in fact failed. If it does, move to the Boot Sequence section of the BIOS. If your hard drive does not show up within the first three boot devices, you probably have a problem. Adjust your BIOS accordingly.
Can't Find Hard Disk Drive Either
If you've done these preliminary checks, and are still receiving the operating system not found error, you could be facing hard disk drive failure. If this is the case, remember : DO NOT PANIC. 99 times out of 100, your hard drive's data can be recovered by a professional firm. So rest easy. Then try this test if you have another computer system available.
First, disconnect your hard disk drive from your system, and connect it to a system you know works as the slave drive.
Second, boot up the system and go into Windows explorer. If you can see the drive, you may not have a problem at all, or have one which can be fixed with simple data recovery software tools (Do a search on Google for data recovery software tools for a selection).
If, on the other hand, you cannot see your drive, you may want to consult a professional hard disk drive recovery shop like Hard Disk Recovery Services. Contact us here for a hard disk drive recovery quote, and we will usually be able to diagnose your problem over the phon
Jun 02, 2010 | Computers & Internet
No operating system
Contact Acer and have them send you a new recovery disk. Be sure to have your computers paperwork handy when you talk to them. The problem" operating system could not be found" could be software or hardware related. I'd try to load the OS using the recovery disk first and see if that fixes the problem... mpawlak
Oct 06, 2009 | Acer Aspire 9300 Notebook
Wmos failure blue screen error message STOP:c00002211
boot your computer with recovery disk thenennter in recovery console mode.
Then type in command prompt 'chkdsk /r'
then press "y"
then it fix bed indexing files.
This eror because of bed index in harddisk.
Also you can repair your operating system with recovery disk.
Aug 15, 2009 | Computers & Internet
Start up problem
This generally indicates a hard drive failure. You can try to do an operating system repair with the recovery or operating system disc, but most likely you will need to replace the hard drive.
When you see the IBM screen you need to enter the boot menu. On this screen it tells you what to press to get to the boot menu. Place the recovery or operating system disc in the drive, and select the CD drive from the boot menu, then follow the directions. If the repair doesn't work, then reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced. You want to do a full NTFS format, not the quick format, if the hard drive is bad, it won't format.
Aug 08, 2008 | IBM ThinkPad T30 2366 Notebook
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
