I had this problem my self flashing charger light but not charging i fixed this by sripping the battery pack unsoldering the positive and negative from the small circuit board geting a 10v charger and directly charging the batery for a few secs checked the battery with a volt meter to insure that there was a charge in it then reasembled then run the player till it was flat put on charge did this a few times this to cycle the battery each time i did this it took more of a charge untill it was back to normal note the light should stay on not flash hope this helps
i had this problem my self flashing charger light but not charging i fixed this by sripping the battery pack unsoldering the positive and negative from the small circuit board geting a 10v charger and directly charging the batery for a few secs checked the battery with a volt meter to insure that there was a charge in it then reasembled then run the player till it was flat put on charge did this a few times this to cycle the battery each time i did this it took more of a charge untill it was back to normal note the light should stay on not flash hope this helps
SOURCE: hi, i have just bought the archos 604. plugged in
If the red led beside the CHG is flashing or on then the device is charging. If not you may have a faulty charger
SOURCE: After charging your portable media
Ifthe MP3 player battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
