Question about BenQ Joybee 130 MP3 Player
Internal 512 is invisible
When i connect my joybee with or without the sd card the internal memory cannot be accessed by either the pc or when playing even in the player menu it shows 0 mb in the player the drive cannot be even formatted so if there is any solution like a driver or software plese help me thank you
  • 196 Answers
There is a switch on the SD card that allows you to lock it. Check if the switch isn't on the "locked" position, that might be what's making its content inaccessible. Hope this solves it!
Posted on Feb 15, 2006
Camera will not allow me to "copy" photos to transfer from internal memory to SD card?
You may be able to connect the camera to a computer and access the picture files that way. Also make sure the SD card isn't close to full.
Jan 01, 2014 | Panasonic Lumix DMC-ZS3 Digital Camera
Took some photos without memory card. The photos are in the camera's memory, how can I transfer those photos into a memory card?
There are some solutions, but the most easy one is:
1. Take the SD card out of the camera and connect it to the pc to transfer the images. After that, put the SD card back into the camera.
2. There is a menu option in the SP800uz to change the memory to Intern, Extern (SD) and Auto (default). Change it temporary to Intern, connect the camera to the PC and transfer the images. Set the setting back to Auto (or else) afterwards.
Sep 11, 2011 | Olympus SP800UZ Digital Camera
What system is the memory formatted in by the camera
I have a Z1285 which I believe has the same internal memory system as the Z12851.
The picture format is JPEG with a file extension of jpg.
When I connect it to my Linux PC, the file format appears to be FAT16.
If I remove the SD card and test it, I get the same result.
I assume the internal memory is formated with FAT16 as well.
This is what fdisk -l shows:
Disk /dev/sde: 1001 MB, 1001848320 bytes
32 heads, 63 sectors/track, 970 cylinders
Units = cylinders of 2016 * 512 = 1032192 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x11762d1b
Device Boot Start End Blocks Id System
/dev/sde1 1 970 977728+ 6 FAT16
Hope this helps,
Feb 21, 2011 | Kodak EasyShare Z12851 Digital Camera
Internal memory
Hi there.
Providing you have a SD memory card in the camera and the card is empty you can transfer all the data from internal memory to the SD card using the camera's menu.
Good luck and thanks for using FixYa!!
May 22, 2009 | Cameras
Dont know how to get pics out internal memory
Actually, you can do it without the cable.
You need to have the card inside your camera with at least ONE picture. Hit play. Press menu. Scroll down until you see COPY and then choose "Internal to SD Card" Hit All Frames. Hit OK. Done.
May 16, 2009 | Fuji FinePix J10 Digital Camera
When i connect joybee in my pc, i can not see my files
umm are your files on the mp3 players hard drive or on an SD card?
if they are on the harddrive, plug the usb cable into computer and mp3player, go to 'My Computer' there should be a new drive found called Joybee '130 (E,F,G,etc:)' double click this drive, withinn the drive should be three folders, FMRadio, MICIN, and MP3, double click mp3, drag and drop (or copy-paste) the mp3 files into the folder and you should be good.
If your files are on an SD card, you will need an SD cardreader, plug the cardreader into the computer, and again drag and drop(or copy-paste) the mp3 files onto the card
May 29, 2008 | BenQ Joybee 130 MP3 Player
Joybee 130 MP3 plaer
Plug your player into your computer via USB. If Windows recognizes it, a new drive should show up under "My Computer". It may be called "Removeable media". It may be some letter like "G" or "H". If you have an SD card bigger than 512 MB, then find the removeable drive that is bigger than 512 MB that shows up when you plug in your MP3 player and that drive is your SD card.
May 02, 2008 | BenQ Joybee 130 MP3 Player
Once you insert the memory card I believe it mixes the songs on the player's internal memory with the memory card's songs.
Jan 04, 2008 | RCA Lyra RD1072 MP3 Player
If I remember correctly, when you insert an SD card, it "hides" the camera's internal memory. There should be an camera option for copying the files from the internal memory onto the inserted SD card. If not, you could try connecting the camera to your computer with the SD card removed, in order to access the files in the internal memory.
Feb 10, 2007 | Samsung Digimax S500 Digital Camera
BenQ Joybee 130 MP3 Player Logo
48 people viewed this question
Top BenQ Audio Players & Recorders Experts
Are you a BenQ Audio Player and Recorder Expert? Answer questions, earn points and help others
