Question about Whirlpool Washing Machines
Does the agitator in our machine have a fabric softener dispenser?
Do not have manual. Am wondering if the cavity in the agitator is for fabric softener.
  • 1,028 Answers
Softner only ..liguid bleach goes in dispenser on right front corner
Posted on Sep 07, 2008
Does the roper washing machine top loader model# RTW4340SQ0 have a place to put in the liquid softener?
I have the same question but have not find a manual or any other reference that tells me whether this model has a softener dispenser or not. However, I just found this info: which is linked to roper washing machine RTW4340SQ0 parts list. It looks as if the washer doesn't come with the softener dispenser as original equipment but that you can buy this dispenser at repair clinic and just assemble it to the agitator as shown in the video that you will find in the link
Jan 13, 2013 | Roper RTW4300SQ Top Load Washer
How do i remove fabric softener dispenser
To remove the fabric softener dispenser, pull up on the dispenser to remove it from the agitator. Grasp both ends of the dispenser and squeeze it in when you are pulling it up.
Feb 10, 2012 | Washing Machines
I have an older Maytag washer without a user manual and was wondering if the cup in the top of the agitator was for adding fabric softener? If it is when do I add it and how much do I add? The model number... I thinking you are referring to item 7 which is listed as a dispensing cup. If I remember right it just sits on the agitator as a means to take off and use to measure soap, fabric softener. Since there is not a water flush line to it, I wouldn't use it to try to dispense the fabric softner. But it probably would do any harm to try it and see how much was actually left in the cup.
Jun 21, 2011 | Washing Machines
Lost manual to maytag legacy series. how do i remove softener dispenser and/or agitator for cleaning and what is the "finger faucet" switch for?
Methinks you need a manual again;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Apr 08, 2011 | Washing Machines
Maytag MAV7000 AWW washing machine agitator won't spin freely.
When you grab the fabric dispenser and move the agitator "counter "clockwise you should hear the rachet noise,once you try and move it back "clockwise" the fabric dispenser should slide inside the agitator and the agitator should NOT move.
Apr 02, 2009 | Maytag Atlantis MAV7000
Gunk in middle of agitator
the fabric softener spins out of the cup after the wash cycle when spinning the water out of clothes, then the washer fills back up for the rinse w/ your softener having been dispensed. is there a nut at the bottom of your agitator where you see the gunk? If so you can take the agitator out by removing the nut but be careful of the little parts that make the agitator agitate. Do not disturb these little parts if you don't know about them. Does the gunk smell like grease or a mechanics garage? If so chances are it is a lubricant and should not be removed replace the cap and your softener cup and continue enjoying your machine.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Agitator Dogs
take the cap or fabric softener dispenser off the top of the agitator. under it should be a clear plastic cap with a little handle on it. take it out. under it should be a bolt (7/16) with a rubber seal under it, take it out and this will release the agitator and you will see the plastic dogs inside the agitator.
Aug 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Nov 28, 2007 | Washing Machines
Whirlpool Style Master 4214164 8 cycle 2 speed -
Don't have a solution but I water down my fabric softener before putting it in machine, especially if you have soft water. AS it tends to gum up because you need to use so little. Hope this helps a littel
Nov 11, 2007 | LG WM-1832C Front Load Washer
Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Apr 09, 2007 | Kenmore 24982 Top Load Washer
Washing Machines Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal De
