Question about RCA MM61110 61" Rear Projection Television
Yellow Spot dead center on screen
I have a yellow spot dead center on my screen. Didn't realize it until my kids played "March of the Penguins" - the yellow spot stood out against the white snow. Any do it yourself remedies for this? If not, what should I expect from a professional repair visit?
  • Anonymous Sep 20, 2008
    I have the yellow area on my sony wega. We even replaced the lamp unit, but it did not help. It is 3 yrs old.
  • Anonymous Mar 18, 2009
    HAVE BIG YELLOW IN THE CENTER OF MY SONY KF50WE610 HELP
I have a panasonic 47" rear projection tv and recently red yellow dots and lines started to show up, what could be the issue here?
these lines and spots aren't external...they are part of the picture itself.
reply would be much appreciated :)
Posted on Dec 31, 2007
    Scholar:
  • 130 Answers
Most likely the yellow dot is due to a burn in the picture on the "green" lens. It's not removable because it's burned it, but you can try cleaning it because sometimes, dots are caused by dirt. The worst that can occur is that if the dot is permanant.
Posted on Feb 14, 2006
I have a 52" rear projuction hitachi tv. I had the same problem. The solution to my problem was something called a OPTICAL ENGINE. It was replaced yesterday and now my picture looks as new as the day we bought it. This part is not cheap. on the invoice it was 921.00 for them to repair my tv with this part. I hope this helps.
Posted on Mar 06, 2008
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
Jan 04, 2012 | Panasonic PT-AE2000U Projector
Spot in center of screen, if the color pictureis black the spot is blue, if the picture is white the spot is yellow.
Spots in screen is commonly caused by defective LCD on the optical assembly. LCD replacement is very difficult. I suggest to contact the nearest service center at your area.
Oct 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I just replaced all 8 bulbs in my projectors. we are a large church and they are used quite a bit each week. when i tested them yesterday, one of my projectors had a yellow dull spot in the center of my...
Hi
If spot is light ( like a clouds ) then probelm is with dust .if is dark then LCD panel is faulty.pl conatc your nearest service centre
ANS BY
M.R. Mumbai & Dubai
Aug 31, 2010 | Sanyo PLC XF45 Multimedia Projector
Hitachi 55vs69a yellow blob in center
you most likely have a bad light engine.
Aug 20, 2009 | Televison & Video
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Big yellow spot in the middle of the screen
the lcd panel for the blue is bad normally you would have to replace the engine but i know a place where you can get it rebuilted for a price cheaper than the engine go to
N-home tvservice.com for some answers
Mar 02, 2009 | Hitachi 55VS69 55" Projection HDTV
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Any color spot is never the lamp with this type of set.
the yellow spot is caused by the optic block (Engine). Very expensive to buy.
Little over $1000 plus labour with a qualified technician.
Sometimes technician may try to clean or repair inside but most likely won't succed.
good luck.
Sep 20, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Yellow spots are appearing in the upper right quadrant of the screen. After the set has been on for a couple of hours a second spot appears in nearly the dead center of the screen. This issue coincides...
Try the new lamp as indicated by the blink codes. That may resolve the problem. If not, the problem is in the "light engine" portion of the set which should be covered under warranty.
Keep us posted.
Dan
May 29, 2008 | Panasonic PT-52LCX65 44" HDTV
Yellow spot in center of screen
I have recently developed the same yellow spot problem on my Sony KDF-E50A10  50" LCD television...a large yellow circular hue that takes up the bottom center of the picture and is especially noticeable against a white background.  It has been diagnosed as the optical block (light engine) and without an extended warranty Sony refuses to assist with the repair cost.  Repair was estimated at $1,100 plus tax and travel fees to my home.  So you see, it is not only a Hitachi problem.  You would think they could build something that would last more than two years considering the initial cost of over two grand for the TV !
Jan 03, 2008 | Hitachi 50V710 50" Rear Projection...
RCA MM61110 61" Rear Projection Television Logo
597 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
