Question about Vitamix 5000 Work Top Blender
Have had my Vita-mix 5000 for several years with no problems. Now, it leaks oily, black liquid around the base, and jerks erratically when the blender is set on the lowest setting (#1 of 10)/variable.
  • 75 Answers
Is it getting hot when you operate it? If you run a mixer for a long
time, the motor will get very warm. On the older units, when the
motor overheats, the various parts of the motor and its container
may start to melt. Mixer motors are not designed to last forever and
a replacement motor may be available from the manufacturer.
Another way is to purchase another similar mixer as you can on
eBay and swap parts.
Posted on Aug 21, 2011
  • dianbaker Aug 21, 2011
    Thanks for responding, but I have not noticed it getting hot. The erratic nature of the blender action starts immediately...
SOURCE:
Where can I buy a clutch for a vita mix 5000
Shop for buy a clutch for a vitamix... on Google
Amazon.com: Vitamix Drive Socket Kit: Electric Countertop ...
www.amazon.com/Vitamix-891.../B0028Y4CVE
Amazon.com, Inc.
Rating: 4.7 - ‎249 reviews
Shop Vitamix at the Amazon Small Appliance Parts & Accessories store. ... blender on the fritz, PLEASE do yourself a favor and check the old drive socket before buying a whole new blender. .... This fitted perfectly into my vitamix super 5000.
Vita-Mix Parts: OEM Replacement Parts ' Parts Town
Dec 03, 2015 | Vitamix Vita Mix 891 - 1-Drive Socket Kit...
Vitamix 5000 variable speed control broken
Have a look at this, this guy has done the job.
http://uppityairlinepilot.blogspot.co.nz/2012/09/vita-mix-5000-variable-speed-fix.html
May 18, 2015 | Vitamix 5000 Work Top Blender
What can I do about my Vita-Mix Blender which leaks at the bottom?
You will need a special wrench to remove blade assembly.
then the gasket/seal is inexpensive.
you can check here:
Contact Us Customer Service Vitamix
or check here:
Vitamix Wrench
Apr 25, 2014 | Vitamix 34000 Blender
Motor leaking dark liquid
Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
Apr 14, 2014 | Montel Williams Living Well Healthmaster...
The buttons on my vita-mix vm0115e wont work. We have been loosing one button at a time. Was going to see if there was a loose cable or something, but I can figure out how to get the base off.
WE do not have your model here in NZ but this is how you get into our models
Remove square rubber base beaker locates onto. Remove motor driving clutch. Remove 4 screws under rubber pad you have just taken off.
Mar 28, 2014 | Vitamix Vita-Mix VM0115E 36021 Blending...
Where can I find a motor
Vitamix says they will fix units up to 20 years old or so????
check here:
Don't know about 30-40 years old????
good Luck
Feb 23, 2014 | Vitamix Vita-mix 3600 / 4000 Handle For...
High pitched noise with use
The problem was the seal was worn, allowing liquid to seep past into the top blade shaft bearing washing out the grease and ruining the bearing. The "noise" you heard was the bearing running without any lubrication. Both bearings and the seal needed to be replaced but I have not found a source for purchasing these. Vita-Mix Company does not sell parts, they sell units (outrageously priced units)!
Sep 03, 2012 | Vitamix 5000 Work Top Blender
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Mar 22, 2009 | Vitamix Super 5000 Work Top Blender
Base leaks heavily when any liquid goes in!
make sure the seal gasket is between the base and the blade base- 99% it will solve your problem!
Aug 27, 2007 | Tefal MagiClean Work Top Blender
Vitamix 5000 Work Top Blender Logo
1,199 people viewed this question
Top Vitamix Blenders Experts
Marvin
Marvin
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
