Question about LG WM-1485FHD Front Load Washer
Cant open soap drawer on washer
The drawer is stuck and I cant figure out how to get it open or off so I can see wants causing the drawer to get stuck.Please help
  • 2 more comments
  • jsisco Sep 07, 2008
    This is a LG WM2277HS
  • stevegourley Sep 10, 2008
    The fabric softner is full of water. How do I get the drawer out to clean?
  • Anonymous Sep 22, 2008
    I can't even get my drawer to open...I am assuming that it is because the "liquid detergent" carpartment is ajar...I don't know let me know if anyone has a solution.
  • rzdave Oct 07, 2008
    Same problem, cant open the soap drawer. Tried unplugging, opening washer door and slamming it closed. Cant figure it out.
I opened up the top of the washer by unscrewing the screw in the back. then I pressed down hard on the white plastic cover of the soap dispenser that you will see on the front left hand side of the machine. I also moved it slightly to the right by pushing on the side of the same unit.
The soap dispenser then opened up fine. I cleaned out the soap dispenser from any crud that developed in it. Now it opens and closes nicely.
Did you know there is a class action lawsuit against LG for mold that develops inside of this model washer? I joined in the lawsuit. There should be no mold accumulating in any washer.
Posted on Mar 01, 2009
  • Erica Trammell Jan 11, 2014
    Hi! Do you have the class action lawsuit information?
    Problem Solver:
  • 5 Answers
Upon taking the top of washer off, it exposes the liquid dispenser. There are three snap clips on the right side as you look at it from the front. Unsnap and lift slightly on the dispenser lid. This should provide the clearance you need to open the drawer. Examine the blue covers for the fabric softener and bleach. You will see scrape marks where it has been rubbing on the the top cover when closing and opening. Using a soldering iron or an abrasive, wear down the sharp edges that are catching...This solved the problem for me.. ( :
Al Holm Chisago City, MN
Posted on Jun 30, 2013
WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
Mar 14, 2011 | LG WM2277HSW XL Front Load Stackable...
Can you use granular soap and where to apply it? we have a frigidaire washer with a drawer to put liquid soap in.
On our washer there is a little slider in that drawer that allows the opening into the washer to open wider for solid laundry soap. Maybe that's the case in yours. If not then you might be confined to using HE liquid soap.
Mar 05, 2011 | Frigidaire ATF6000ES Front Load Washer
We had a LG WM2077CW washer and it has a stuck soap drawer. It happened about a year ago and I was able to jiggle it open. It has stuck again and there seems to be know way to get it open. Is there a quick...
a couple of screws at the back of the machine hold the lid on take the lid of and you can see whats going on in there make sure the power is turned off so you dont get zapped then see if you can get a screwdriver or something in there to wedge it out this is all the service guy will do for $150 you might have to shave the plastic back a bit on the soap drawer with a stanley knife so when you put it back in it doesnt get stuck again.
Jan 11, 2011 | LG WM-2077C Front Load Washer
We have a Kenmore frontloader pooring water from soap dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 16, 2009 | Kenmore 44102 Front Load Washer
Indesit WIE147 leaking from soap dispenser
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Jun 17, 2009 | Washing Machines
Soap Dispenser won't empty
Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
Soap Dispenser drawer will not open.
Feb 22, 2008 | LG WM1814CW Front Load Washer
Opening the top of front load LG washer
to get your lid of the washer there are 2/3 screws at the back right under the lip of the lid once you have taken the lid of u will see the top of the soap drawer u can sometimes get into these by undoing the clips on either side of the soap drawer if u cant do it that way only other way is to make sure your soap drawer is closed properly and hit it hard at the front it should dislodge more than likely your conditioner drawer
Aug 15, 2007 | LG WM-2277HW Front Load Washer
LG WM-1485FHD Front Load Washer Logo
1,932 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
