RCA 32" HDTV MODEL # L32WD12YX5 Television will not turn on. It makes a clicking noise when you press the on button but nothing happens.
  • llangenhoff Sep 07, 2008
    I heard a very brief noise when I turned the TV on and then it would not start.
    How expensive is this problem generally? The TV is only just over a year old, (of course off of warranty) Is it worth fixing or am I looking at replacing it?
    Sergeant:
  • 241 Answers
Servicemanuals.vstore.ca/This is the convergence power suply is usally the problem
and the servicemanuals.vstore.ca/index.php/cName/flybacks
The Fly Back are the cheapest to replace
Posted on Sep 07, 2008
  • 1,879 Answers
Call for service if you are not a certified electronics technician.
    Genius:
  • 1,269 Answers
All you need to do is have it check by a tv technician. If you TV is still under warranty, better call the retailer or the manufacturer to claim your warranty instead of investing money for repair. If your TV is out of warranty, have fix by a tv tech if you have no knowledge on basic electronic troubleshooting. The problem there is a faulty component on the circuit board inside the TV. It might be a burned capacitor, IC or fuse. Definitely, the power supply circuit has been affected by a sudden power fluctuation or something like that.
  • 1,031 Answers
The most common problem with this is the start up circuit of the power supply
  • Starnley Johnwells
    Starnley Johnwells Sep 07, 2008
    these clicking noises were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
    disconnect any allow the internal cct to reset then turn it on again .the noises may stop after some minute
    if it doesnt work then you need a technician to look at the power start up circuit
  • 19,396 Answers
The clicking noise is the internal safety switch preventing the tv from turniing on.
When this happens it means the TV has detected an internal problem, for example an overvoltage, a short or a faulty component. the safety switc keep TV off to prevent further damage.
Try unplugging TV power cord for one or two hours.
If this does not work a technician will need to test onboard components inside your TV.
If you need a technician you can use the phone number listed on the owner manual.
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
When i push the power button on my rca hdtv r52wh73 the green light comes on it makes a squeak noise like it is trying to power up but nothing happens.
replacing the deflection board will solve that issue about 95% of the time. You need the ITC222A deflection board PSB260 which you can get from www.tvrepairworld.com listed under the RCA Projection circuit boards. It comes with installation instructions.
Jun 24, 2012 | RCA R52WH73 Projection Television
Hi, I have an RCA HDTV SRS WOW Model RCA L32WD12YX5, Serial G482CJ060. It powers on and has sound for about 15 minutes then shuts itself off and restarts with no sound. As an experiment, I used the Menu...
The tv main Tuner signal board have problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Jun 09, 2011 | RCA L32WD22 32 in. LCD HDTV
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens...
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Apr 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA big screen won't turn on, it clicks 3 times and then nothing. I have sat there for an hour and it has turned on with me continually pressing the on button every 45 seconds. But today it would not...
Bad Capacitors on Deflection Board CP114 ,CP120, CP150 2200uf 16v use 25v. other 2 caps are 220uf 35v
Deflection board is bottom left hand side Board,has FBT flyback transfomer
Oct 03, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA DLP HDTV making terrible noise
your color weel is going bad and needs to be replaced
May 19, 2010 | RCA HD52W59 HDTV Projection Television
RCA HDTV - problem turning on
It's on but you are on the wrong input. check your connections from your sources ( i.e. dvd, vcr or satellite/cable box) try pressing source or input button on tv remote
Jul 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not turn on
Look on Deflection board 3 capacitors need replacing cp150---cp114----cp120 one is 2200uf 16v Two of them are 220uf 35v. Buy capacitors at Radio SHack. If cp150 is puffed up on top it is bad so replace other 2 caps as well.
Dec 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
233 people viewed this question
Top Televison & Video Experts
