Question about Acer Aspire 3050-1733 Notebook
Power I am unable to power up on the computer. Hit the on/off switch, and nothing. I've tried it with and without battery pack to see if it was faulty battery, and have the same problem when using directly via A/C adapter.
  • Anonymous Nov 25, 2008
    i hit the power button and it turns on but no screen and no booting up
  • Anonymous Jan 07, 2009
    i hit the power button and it turns on but no screen and no booting up on my aspire 3050
Only one ward..personal experiance with ACER products...i just stay away from everything that has ACER name in it
Posted on Sep 07, 2008
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
Compaq presario v6317 not turning on
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
May 04, 2012 | Compaq Presario Computers & Internet
No power to dell d620 laptop with or without battery, looking for a possible main fuse problem, where could i find it. thanks
The you most likely have one of two things for fuses places, (1) on the motherboard at the power connectors, or (2) there could be multiple fuses (ie. one in the battery, one in the power adapter, and maybe one on the motherboard.) the latter is rare but I've seen it. It doesn't really matter though because any fuses are most likely soldered in and you'll need special tools to change them without causing more harm then good.
However, if your computer is having a problem where it just plain won't turn on (ie. hit the power button and nothing happens at all), with laptops, you could need a new computer.
Sep 07, 2011 | Dell Latitude D600 Notebook
Hi, I've APC UPS ES 500 connected to my desktop computer. Have 1 year old battery but when checked without load displaying 12 V. Issues are: a. ups doesn't supply...
A battery showing 12V without a load attached means nothing. You probably have one or more weak cells and they simply cannot supply enough power. I would try a new battery before I try anything else.
Jul 21, 2011 | Office Equipment & Supplies
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a message to power on and off again. I\'ve tried switching on and off a few times, removing battery pack and memory card, but nothing seems to be solving the problem.
Feb 19, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
Computer freezes when connected to external power supply. Works perfectly on battery power, but freezes on Windows shut down.
take out the battery and try without battery installed
if still the same then your power socket is faulty or the power pack is faulty
replace it and you'll be running again
Apr 11, 2010 | ASUS RECERTIFIED: PC-DL 533MHz FSB Dual...
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Jan 08, 2010 | Dell OptiPlex SX280 PC Desktop
Computer won't turn on. d600
If you have replaced the power pack (assuming the power pack is BRAND NEW and has a green light to indicate that there is power going into the adapter) i've seen cases where the green light is on the power pack but no juice is flowing to the laptop - so if its2nd hand i'd look at a new one.
Failing that remove battery and try - battery could be casuing the motherboard not to accept power due to faulty battery
Failing you have tried all the above then it looks like your motherboard needs replacing
Jan 10, 2009 | Toshiba Tecra A5-S416 Notebook
No power after cleaning the motherboard
Damn, you got some bad luck there. without actually haveing the laptop in my hands I can't offer much assistance.
Try to turn it on with and without the battery, then with the battery and without the charger. if noting happens after a few trys you can open it up again and look if something smells bad or looks bad (black or otherwice burned)
Of you can take the laptop to a pc repair center for analysis.
Feb 23, 2008 | Sony VAIO FRV37 Notebook
Acer Aspire 3050-1733 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
