Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Model 9p6034c1 serial 28065476
We purchased this tv in april 2000 and absolutely love it. we have had no problems until now. the problem started with turning it on we would get a small concave looking picture with pink and green around in and the picture would eventually come on. the picture eventually started to pop in and out, and now the picture won't come on at all.
We would like to know what the problem is, can we fix it, or do we need someone to come here to fix.
Please help......thanks! debs416@gmail.com
  • debs416 Sep 26, 2008
    Thanks for the help. We had a repairman in today (9/26/08) and he said our problem is the 'deflection', which, from what I understand, is the main power source inside the TV. Now we're waiting for parts to come in, I'll let ya know...debs
  • Philips Master
  • 3,459 Answers
If the screen shrinks and expands its a common problem. Check the site www.magnavoxhelp.com for a chip kit to fix it.
Posted on Sep 19, 2008
  • Edward
    Edward Sep 27, 2008
    Did you try the chip kit I mentioed above before calling in the repair tech?
    The chip typicaly fixes this exact problem - shrinking/expanding video.
Optical Block needs replacing
unfortunately the optical blockissue kills any resale value except for the chassis boards value for used boards. Parting it out will be your best bet as alot of people may be needing the boards.
Feb 27, 2013 | Sony KDS-60A2000 60" HDTV
Hello, i am trying to find out when the MDE6400AYA was made.. What year
Hello there.
You will need to write down your SERIAL number from your model/serial tag.
Example: 15114672UY...... UY is the date code. First letter is the year, second letter-month.
1980 E March
1981 G April
1982 J May
1983 L June
1984 N July
1985 P August
1986 R September
1987 T October
1988 V November
1989 X December
1990 B Jan.
1991 D Feb.
1992 F March
1993 H April
1994 K May
1995 M June
1996 Q July
1997 S Aug.
1998 U September
1999 W Oct.
2000 Y Nov.
2001 Z Dec.
2002 A Jan.
2003 C Feb.
2004 E Mar.
2005 G April
2006 J May
2007 L June
Hope that helps,
Mike
Jul 27, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Could you please let me know when my Maytag fridge was made. Model PTB1753DRQ Serial 12494169YH Thanks
According to the serial # breakdown it was April 2000.
http://www.electrical-forensics.com/MajorAppliances/MaytagDateCodes.html
Apr 21, 2011 | Refrigerators
None of the universal remotes work.,
Try website like 1-800 Remotes Factory Original.Buy the exact remote to the original.
May 07, 2010 | Curtis-Mathis CM27101S TV
Lost my serial number, but I know the model# HD52W59
The only way to get SN is if you sent in for warranty
and you still have owners Manual it will be printed on it.Other wise you have no way of getting SN unless you wrote it down when you purchased TV
Apr 09, 2010 | RCA HD52W59 HDTV Projection Television
Panasonic Viera TH-46PZ85BA Will not switch on
Yes, the unit has a problem. I work for Panasonic in New Zealand and the unit needs to go in for servicing. 10 flashing lights means a fault has occurred (if I was at work I could tell you what 10 flashing lights means).it should be repairable.
Sep 26, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Microwave Not Nuking Anymore
It sounds like the high voltage rectifier has shorted or the magnetron has failed.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
http://www.gallawa.com/microtech/xformer.html
Nov 22, 2008 | Whirlpool MH6150XMS Microwave Oven
Radio Shack Universal Remote 15-2146 Closed Captioning Issue
I would make sure that you have the correct model code for the universal remote. I've actually had the same problem because I used the wrong model code. If it's correct, start over. disconnect everything, (will reset all options) and that should solve it.
hope i helped.
Oct 15, 2008 | Radio Shack 15-2146 Remote Control
For lg monitor warranty
this monitor having 3 yr warranty
according to the serial no it have warranty till April 2008.
Feb 05, 2008 | Gateway FPD2275W LCD Monitor
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
