Cars & Trucks Logo
Posted on Aug 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I do not know how to open my trunk manually, a 2007 misubisi eclipes....my key, remote will no longer open it..what can I do?
Anonymous
Level 2:
New Friend:
  • Expert 67 Answers
  • Posted on Aug 21, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
67
Questions
0
Helped
21386
Points
192
There should be a small black button in the middle of the trunk and as long as both doors are unlocked it should open the trunk.
Trunk release does not work
There is no key cylinder to open the trunk?
Have to go to a repair shop & ask what they do
.2007 Toyota Camry XLE key fob not opening trunk remotely...also starting to have problems with it opening driver side door
First things first...replace the cheaper part first, the battery. It that works, great! If not, then you may need a new key fob then have it programed to your system.
1helpful
Lexus 2007 RX350 trunk door doesn't open or close from key, trunk button and power door button
OPEN MANUALLY AND CHECK THE STRUTS PS. IF WHEN YOU OPEN IT AND IT GOES BACK DOWN THAT'S YOUR PROBLEM
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
1helpful
Trunk won't open
First, if it does need an actuator, you can save some money on labor getting it done at an idependent aftermarket shop rather than the dealer. Yes, the part will most likely have to come from the dealer, but let the shop deal with that. You do not have to pay dealership labor rates. It would pay to shop around.
Second, before any parts are purchaced, the actual CAUSE of the problem needs to be verified. Unfortunately, the ONLY way to do that is to get the trunk lid open and inspect the trunk lid latch components. If none of the three methods provided by the manufacturer for opening the trunk in a normal fashion will work, the trunk will have to be accessed by removing the back seat. Once the back seat is removed, a technician can reach into the trunk and remove the bolts that secure the trunk latch to get the trunk open. The latch parts can then be accessed to disassemble, inspect, and repair accordingly.
Please note that this is the ONLY way to do this without causing further damage to the vehicle. DO NOT allow anyone to attempt getting into the trunk any other way! (Do not use pry bars or screwdrivers on the trunk lid, key tumblers, etc..)
Hi i would like to know if there is a fuse for the trunk in my saturn ion quad 3 2.4 auto 2007. The trunk is operated by a key less remote and i would like to know if i can prevent this.
Not sure. You may look in the owners manual and see if there is any type of VALET mode to prevent the trunk from opening, of course if they have the KEY it wont matter. you can always disconnect the wires that go to the truck latch assy.
3helpful
Can't open trunk with remote control. When unlock, I can't open the trunk manually either. Use key turn ccw and able to open trunk. What wrong. Handle issue?
2007 then to re programme key it needs dealer software diagnostic machine ,if this is the problem but i think the problem is the operating solonoid in the boot ,i think it may be stuck or sticking ,locking but not releasing and if this is the case then remove the panel and oil the rod on top of the operating mechanism with engine oil so it soaks down into the solonoid and after a couple of days it should free its self up .
3helpful
The trunk on my 2000 volvo s-40 wont open
you'll need to insert your key into the trunk lock. prior to doing this you'll need to use the automatic lock on the driver side of the vehicle, hit the unluck button twice. Torn the key in the trunk to the left, you may have to slightly press the trunk button in while doing this and give it a lttle wiggle after the key has been turneed to the left push the button all the way in, if this does not work repeat the process but reverse to the right instead of the left.
This manually disables the remote lock for your trunk.
1helpful
2007 aston martin db9 volante jump start battery
u have to take the valet key out of ur remote. It will open the trunk, it can just be very hard to turn but it will i do this all the time.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
