Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 50v500 My television has blue streaks across the television.
  • Anonymous Oct 12, 2008
    mine started w/ a cloud in rt.hand corner of screen, within 1month, it has coverd half the screen, is that because the bulbs are burned out. also i have shadows on the screen, it's worse when letters or numbers are on the screen...thanks for the help....
  • Anonymous Oct 27, 2008
    I bought my television January 05. For the past 3 weeks i noticed that a have a blue streak in the center and the sides of my screen.I'm very disappointed that this is happening.Could it be the lamp or a inside panel ? Can we repair ourselves or do we need a Technician?
    Let us know.
5 Suggested Answers
  • 58 Answers
SOURCE: Hitachi 50v500 blueing problem
I am not expert but before you go to a lot of trouble, read all of the post on the infamous "red cloud", "red blob" and "blue streaking". In evey case, it appeared that the light engine was the problem. We just had our light engine replaced and the TV looks perfect. We dealt only with Hitachis Customer Relations Department 800-654-7013. You will have to have a certified tech come out and diagnos the problem. Hitachi will then call and verify, with the dealer, that the problem is a defective light engine and will send out a brand new one.
We were told the part cost around $1500 (Hitachi covers that) however, they will ask you to pay for the install. Our install cost $400. Worth is to us as we paid $3600 for this set 3+ years ago and we have loved this TV. When you first call Hitchi, they will act like they've never heard of this problem but they will give you names of certified techs in your area. Once the tech confirms that it's the light engine, Hitachi will own up to the problem and send out the part.
You really should only deal with Customer Relations ( I listed their 800 number above as you will be chasing your tail so to speak with their regular customer service department. Good Luck!
Posted on Nov 25, 2007
SOURCE: Hitachi 50V500 tv blue shadows
43fdx10b has blue shadows? How can I fix it? I don't find an LCD screen when I follow your instructions...bccause the model is slightly different.
Posted on Jun 30, 2008
  • 213 Answers
SOURCE: my Hitachi 50v500 rear projection lcd TV has a
bad stk 392-???
Posted on Sep 09, 2009
SD Tech
  • 14553 Answers
SOURCE: My Hitachi lcd rear projection 50v500 television
THIS IS A VERY COMMON PROBLEM IN BOTH THE 50V500 AND 60V500---IT IS A BAD OPTICAL LIGHT ENGINE---MAJOR PART---WHOLESALES FOR OVER 600 DOLLARS!
IF YOU HAVE AN EXTENDED WARRANTY---GET IT IN FOR REPAIR!
There are already several class action lawsuits in several states concerning this problem in this model.
What happens is the lamp the set uses damages lens etc inside the light engine--the engines are now being sold on an exchange basis and are all rebuilt units---that are supposed to not have the same kind of problem as the early ones.
If this helps you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 12, 2009
SOURCE: hitachi 50v500 reddish cloudy swirl sweeps across
motherboard has gone out cost is about $700 including labor i just was quoted that price mine is doing the same
Posted on Jan 31, 2010
Hitachi 50v500 reddish cloudy swirl sweeps across
Jan 31, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500a blue streak in middle about 6to8 inchs wide
Sounds like a light engine issue. Replace it but it might be costly.
Dec 02, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue Streak
I had the same problem w/ the same TV about 6 months ago. You need a new optical engine. Hopefully you are still under warranty. Once that was replaced, the tv looks great.
Dec 26, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Nov 24, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
If it's a ghosting problem that looks like this:
it's probably something you can correct yourself...
Nov 21, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
16 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
