Question about SanDisk Sansa Clip MP3 Player
Help plz I'm trying to download music on my sansa by using my media player, but it says i don't have it connected plz help.
  • 24 Answers
You need to update your version of media player. You have to go to windows and update your service pack to service pack 2. If you are running Windows XP make sure you have service pack 2... Let me know if that helps...
Posted on Sep 12, 2008
I have a SanDisk Sansa how do I download the music from my Imac to the Sansa, I've connected it to the Imac but I don't see how to downlaod the music
Is the SanDisk showing as a drive on the Imac? You should be able to drag files from the Music folder to the Sansa player to copy them. (You can't connect to ITunes and download directly to the player.)
I hope this helps.
Mar 25, 2013 | SanDisk Sansa Audio Players & Recorders
How do i transfer music from my sansa clip to my computer
Syncing and transferring music files to the Sansa player using Windows Media Player 10 How do I sync or transfer music files to/from my Sansa player using Windows Media Player?
STEP 1 - Connect the Sansa player to the computer
STEP 2 - Run Windows Media Player
1. Go to Start > Programs > Windows Media Player.
NOTE: If you can not see Windows Media Player on the menu, go to Start > Run then type WMPLAYER then OK.
STEP 3 - Sync files to the Sansa player.
1. Click the Library tab.
2. Drag the music files to be transferred on to the right panel.
NOTE: You can also right-click on the title of the song and select Add to sync list.
3. After creating the list, click the Start sync button to sync and transfer music files to your device.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | SanDisk Sansa Clip MP3 Player
How do you download music on your sandisk?
i know how to load music to sandisk sansa player.
NOTE: If you're using a MAC, see answer ID 1141
METHOD 1 - Load and sync music files using Windows Media Player
METHOD 2 - Copy & paste or drag & drop music files to the player through "My Computer".
1. Connect the Sansa player to the computer.
2. Double-click My Computer.
3. Locate and select the music file(s) to be copied to your Sansa player .
NOTE: You can select multiple files by holding the CTRL key down while clicking files. You can also select all the files on that particular folder by holding CTRL key then pressing A.
4. On your keyboard, hold the CTRL key then press C to copy.
5. Under My Computer, double-click the Sansa player.
NOTE: If the Sansa player is connected in MSC mode, you will see something similar to the image below:
If connected in MTP mode, you will see something similar to this:
6. Locate the Music folder and double-click to open.
NOTE: In MTP mode, you may need to double click on Internal Memory to get to the MUSIC folder.
7. Hold down the CTRL key on the keyboard then press V to paste the music files.
If you want to enjoy more music and video on Sansa Media Player, you can try this guide.
Mar 02, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Someone gave me there Sansa Fuze mp3player but they didn't have the instruction booklet. I'm trying to find out how I download things to the mp3 player
You need a USB cable which you need to connect to your computer. This cable also serves as a charger. You will probably need to load(rip) the music from a CD to your computer into a program called Windows Media Player. Then you will use this program (Windows Media Player) to "sync" your MP3 player to the computer from which you can download music to your MP3 player.
Sep 14, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa 2.0 gb mp3 player having trouble getting it to
I had the same problem when I connected to the computer. So I used my friends Labtop definite 2.0 usb. Did you try to update your sansa click on link and download install run connect sansa when asked.
this has the manual also Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa ) easier not to sync
I hope this works
Apr 19, 2009 | SanDisk Sansa E280 MP3 Player
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software ( download to a flash drive much easier Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa )
Apr 14, 2009 | SanDisk Sansa e260 MP3 Player
Sansa SanDisk
how download plz explaine better
Jun 16, 2008 | SanDisk Sansa E280 MP3 Player
connect to your pc using usb connection. sansa should be recognized as storage media drive. navigate to the drive. Drag and drop files to music/video folder. Enable show hidden files and folders in your windows folder settings. Tools>Folder Options>View. Some of the folders are hidden. You can delete the preloaded music also.Some of them are in the radio folder.
Feb 02, 2008 | SanDisk Sansa e250 MP3 Player
Cant load songs
the best way for that is to read your manual.
Windows XP SP1
Intel Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sandisk sansa c200(2gb)
Do you use windows media player 10 or 11 to sync music into the mp3 player? and have you updated firmware? Go to and download a firmware updater and then try formatting the mp3 player, use WM and click on the arrow below sync and go to format.
Jun 10, 2007 | SanDisk Sansa c200 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
