Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV will not turn on
The power light will constantly blink on and off but the tv will not turn on at all.
  • RCA Master
  • 8,617 Answers
Can you respond to this same post and let me know if it blinks 3 times or what the number of blinks is and I will try to assist you.
Posted on Sep 07, 2008
My tv comes on then goes out within 5 min. Says no signal. Cable came out it is the tv. So we turned off then let it sit off for 4 hrs, turn on then 5 min off again. Any help on this .
Samsung 450 tv will not power up/on red light blinking constant
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/
Sep 21, 2014 | Samsung Televison & Video
I have a 50" plasma tv turn it off and the nex day it would not come on. The stand by light is on but when uou turn ti on the green light comes on but fades back to stand by.
hmmmm..sounds like the control board has taken an early exit from operation. anything happen to the tv power wise recently?
Mar 10, 2008 | Televison & Video
What does a orange not blinking indcator light mean?
For your TV the power light will be red when the TV is turned off using the power button on the top of the TV. Press the power button on top of the TV if that does not work then try turning the power off at the power switch on the bottom of the TV then turn it back on after a minute ior so and see if you can turn it on using the power button.
Aug 05, 2014 | Protron PLTV-37 37 in. LCD Television
TV power lights blinks on after turn on.
you need to post make and model#
Dec 31, 2013 | Televison & Video
My 40" Toshiba LCD TV (model 40RV525U) won't turn on. While plugged in the green power light constantly blinks, but the TV won't power on. Unplugging the TV stops the power light from blinking, but once...
These blinks are fault indications, and are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you're sound in electronics, this will make the repair easy. If you wish to get more details about these blinking codes, check this link. Blinking codes to many brand TVs are described in detail. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 06, 2013 | Toshiba 40RV525U 40 in. LCD TV
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Tv will not turn on but it constantly blinks and will not stop
You need to change the seven capacitors on the DM power supply board (inside the metal case on the left where your DTV tuner connects)They are 1000 MFD 16 VOLT capacitors and the tops are probably bulging outward because they are leaky- this is a common problem.When you lost power,the TV had to reboot itself but because of the leaky caps it never will and the green light keeps blinking.As long as you never lost power or unplugged the set the TV would of still worked.Once you change the parts and plug the set in the light will blink normaly for about a minute and when it stops blinking you can then turn on the TV.
Aug 30, 2007 | Mitsubishi WS-55859 55" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
