Question about Toshiba Satellite A135-S2276 Notebook
I was downloading, after ten minutes it was turned off
I was downloading music and when I came back to check the progress, I saw the laptop turned off. I tried to turn it on but the only lights that appear at that time are the on-off buttons which stay on only for 2 seconds and then off again.
    Problem Solver:
  • 6 Answers
You are having the same charging issue that many other owners of this laptop are having. The power module where you plug in the AC adapter to the computer is defective. This is a known issue that Best Buy usually can't figure out. I sent mine back to Best Buy 4 times under warranty and they were unable to fix it.
If it's still under warranty tell them to replace that power plug circuit board or whatever it is and it will work fine. Mine has been working fine since Toshiba replaced that part 6 months ago.
Posted on Oct 22, 2008
  • 56 Answers
Make sure that the computer was not on sleep mode or hibernation. word of advice, when you try to download something from the internet be sure that the ac adapter or charger is connected at all times to prevent the computer from going to hibernation. you can disable hibernation by going to toshiba power management console.
i hope this info helps.
Posted on Sep 17, 2008
What would cause a poulan chain saw to quit running after about ten minutes of cutting
The only temperature sensitive part I can think of is the condenser. In most saws it is under the flywheel with the points. Some newer saws have an electronic ignition module. If that is the case the module must be replaced.
Oct 15, 2014 | Poulan Garden
Tip
Relearning key ignition on 2000 and up gm
Turn the key on,and leave it turned on for ten minutes,then turn key off,and right back on,leave it ten minutes,and turn it off,and right back on,leave it ten minutes,then turn it off,and right back on,,,,This is a total of three times,,and a total of thirty minutes,then the ignition key will be relearned,to the vehicle.This will work for most 2000 gm products and up.
on May 07, 2010 | Chevrolet Malibu Cars & Trucks
Music video plays then stops with a small circle of dots appearing in the center of the screen wait a few minutes music re-starts then stops again
your internet speed is not enough to play online using idm download video from youtube then play it any time.don't forget to turn on advance downloading option from option menu.then you will able download.
May 11, 2011 | YouTube Videos
I have been using my Craftsman 10" Table Saw to
First things first, check the outlet that the saw is plugged into. Does it have power? If so then progress to the saw itself and check the reset button which is usually located on the front panel but sometimes on the back or sides. Press the button firmly to make sure it is not tripped and if it is this will reset it. Make sure the power is turned off and attempt to turn the blade manually ( caution,
the blade is sharp so a pair of gloves is recommended ). If the blade turns with very little resistance then turn the power back on and try the on/off switch. If the saw starts it may very well have been the circuit breaker that had tripped.
Mar 02, 2011 | Craftsman 10" Table Saw
New battery, all fuses good all electrical systems good engine will not turn over
Try relearning the key to the ignition,,,turn key on,and leave it on ten minutes,then turn it off,and right back on,leave it ten minutes,then turn it off,and right back on,and one more time,a total of 30 minutes,this should do it,if this is the problem.
Jun 23, 2010 | 1999 Oldsmobile Cutlass
Dishwasher runs for about ten minutes
There may be a heating problem,if the water doesn't heat, the cycle can't progress further.
May 30, 2010 | LG 24 in. LDF 7811 Stainless Steel...
My ipod wont get off music
Perform a "Hard" Reset (Restore)
  1. Load iTunes on your computer, and make sure that you have the latest version. Verify that all your music is backed up. Performing a hard reset will erase all content from your device.
  2. Connect your iPod via the USB cable.
  3. Wait for your Ipod to appear in the iTunes source list on your computer. If it does not appear, then you may have to connect in "disk mode."
  4. Select your iPod from the Source list, and select the "Summary" tab if it is not already selected. You should see information about your iPod displayed on your computer screen.
  5. Click on the "Restore" button. This will begin the first stage of the process of resetting your iPod to its original "out-of-the-box" condition. A progress bar will let you track the process. It may take several minutes. Once it has finished, leave the iPod connected to your computer.
  6. Watch, as the next stage begins automatically. The Apple logo should appear on your iPod's screen, along with a new progress bar. Wait for it to finish, and leave the iPod connected.
  7. When a new window appears on your computer screen, follow the prompts for naming your device and setting your preferences. When finished, you may re-sync your music and disconnect from your computer.
Sep 24, 2009 | Audio Players & Recorders
Stuck in hibernation
turn system off remove battery...leave alone for ten minutes...have a cup of tea...
turn system on ..leave battery out use mains only.
boot up ..then turn off properly..
now insert battery and happy days.
boot up
Sep 15, 2009 | Compaq Armada E500 Notebook
Booting problem
Sounds like you need to reboot it from the startup disks provided. first though, check in the BIOS to see if you have the correct boot sequence. You may also need to check for virus if the music was downloaded of the internet.
Sep 07, 2007 | Dell Latitude C610 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
