Question about Refrigerators
Maytag top freezer refrigerator leaking water
I have a Maytag refrigerator that has just started leaking water underneath. I have checked the defrost plastic tub in the back of the refrig and it appears to be fine. I found a plug for the icemaker but can't find where the plug goes. The icemaker is not hooked up. Could that be the problem?
Thank you for your help.
  • 2 more comments
  • Debi Fetterman Sep 07, 2008
    Do you have any diagrams to show me where the icemaker and other areas you spoke are in my model PTB1953GR
  • Debi Fetterman Sep 08, 2008
    I have Model #PTB1953GR refrigerator. It has started leaking water underneath the refrigerator. I have checked the defrost tube and tray and they appear to be fine. Where else could the water be coming from? It has an opening to connect a ice maker but there is no ice maker. I noticed in the freezer that the plug for the icemaker opening was not there and the opening had ice in it. I melted the ice in the opening and placed the plug in but it is still leaking.
    What else is there to check then?
    not one of the "experts" have answered my question directly. I want my money back!!
  • 2,071 Answers
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Heavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Hope this may help you;
Regards,
VOTIT
Posted on Sep 08, 2008
  • 1,800 Answers
This problem is always occured by the a weak motor or not enough gas so check them both and u will solve it ^^
best regards
plz do rate this poste
    Master:
  • 638 Answers
After checking everything if it still leaks it is quite possible its due to some breakage in the unit.check it overall.
  • Refrigerators Master
  • 19,396 Answers
Perform a complete overnight defrost, sometimes ice accumulating inside the fridge can cause leaks.
Posted on Sep 07, 2008
  • Ginko
    Ginko Sep 07, 2008
    Generally
    • If
      the water is coming from the ice maker water valve, check to make sure
      the water tubes are attached properly and are fastened tightly.
    • If the water seems to be coming from any part of the valve itself, replace the valve.
    • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
    Check also the following suggestions from Repairclinic
    It leaks
    Water can leak from these areas:
    The bottom front of the refrigerator or freezer door
    The back of the refrigerator
    The inside ceiling of the refrigerator
    The inside back wall of the refrigerator
    Underneath the front of the refrigerator
    Self-defrosting
    refrigerators usually dispose of the water generated during the defrost
    cycle via a tube or channel that directs the water to a pan at the
    bottom of the refrigerator. From the pan, the water normally
    evaporates. (See a more detailed explanation of this in the How Things
    Work section of our website).
    If the tube or channel is clogged
    or obstructed, the water backs up and leaks into the inside of the
    refrigerator compartment. Then the water builds up at the bottom,
    inside of the refrigerator. When the water has built up for a time it
    may spill out of the front of the door opening. To fix this problem,
    clear the drain tube or channel and allow the defrost water to flow
    down to the drain pan.
    In some refrigerators, the defrost
    water is intentionally directed down the back wall of the refrigerator,
    where it then flows to the bottom of the refrigerator compartment and
    out to a small drain--usually located beneath one of the drawers at the
    bottom of the refrigerator. If the drain becomes clogged or blocked,
    the water may back up. To fix this problem, clear the obstruction.
    Another
    cause may be the following. The refrigerator may have doorframe heaters
    to evaporate any condensation on the cabinet frame. If your
    refrigerator is equipped with a switch inside that says “energy saver”
    or something similar, while running in that mode the door heaters are
    disabled. Turn the switch to the opposite setting and wait 24 hours. If
    the condensation disappears the problem is solved.
    Water
    coming from the back of the refrigerator usually comes from either the
    ice maker water valve or line (if there is an ice maker), or from the
    defrost drain pan.
    Water
    accumulating on the ceiling of the refrigerator is usually caused by a
    clogged drain in the freezer section beneath the evaporator. The
    clogged drain will cause water from the self defrost cycle to leak into
    the divider between the freezer and refrigerator. This water may then
    freeze and cause condensation build-up on the refrigerator ceiling. The
    solution to this problem begins with unclogging the drain. It may also
    be necessary to remove the entire freezer/refrigerator divider to
    thoroughly dry the insulation in the divider. Occasionally the
    insulation needs to be replaced to prevent a recurrence of the problem.
    This can be a big job – you may want to hire a qualified appliance
    repair technician.
    In
    some refrigerators, the water from the defrost cycle is intentionally
    directed down the back wall of the refrigerator, where it then flows to
    the bottom of the refrigerator compartment and out to a small drain -
    usually located beneath one of the drawers at the bottom of the
    refrigerator. If the drain becomes clogged or blocked, the water may
    If
    the refrigerator is equipped with a water dispenser on the freezer
    door, check if the water line to the dispenser is leaking. Also, check
    the drip pan to be sure it isn’t out of place, broken or cracked."
  • Ginko
    Ginko Sep 07, 2008
    Check here, you will find complete exploded views , to view the diagrams just click on the part.You can also buy parts from same website in the eventuality.
    If you want to order the complete repair manual you can call them toll-free at 1-888-895-1535 from 7:00 AM to 9:00 PM Eastern time, Monday to Friday and Saturday from 8:00 AM to 6:00.
I have a 2010 3 door Maytag/ice-maker it has a frost build up in the freezer built up with water spilling out from underneath it. what could the problem be?
This is the defrost cycle that is not working correctly. The timer could be stuck. The drain hose for the defrost might be plugged also.
Sep 28, 2014 | Maytag Refrigerators
MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
My refrigerator is leaking water under the refrig and I have turned off the water to the water dispenser and ice maker. Water is still leaking. what would the problem be?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 24, 2011 | KitchenAid Refrigerators
We have a kitchen aid refrig ktrs21kf leaking water into refrig bottom. not sure where it is coming from. comes down through a couple sm holes encased in styrofoam. Can I fix this myself?
Leo Ponder
imufo2
Aug 19, 2011 | Refrigerators
Maytag top-freeer is leaking water onto the floor - how do I unclog the drain?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 28, 2011 | Maytag MTB2456G Top Freezer Refrigerator
Refrigator not cooling -freezer section icing up. Maytag MSD2432GR Have had it six years never had a problem. Pulled lower back pannel cleaned back of refrigator of dust with a vacuum didn't notice any...
At the moment I would look inside the fresh food section and behind the controls there there you will find the defrost timer. On most you need not take the control panel apart but look for a hole with a plastic plug covering the hole. The part is=> 68233-2 Defrost Timer 8 Hour You may also manually defrost your refrigerator by unplugging the power and removal of frozen good to a ice chest. Either use a hair drier once removal of the rear panel in back of freezer or place a bucket of hot water inside and close the door and wait. Sometime beaware that a lot of water will drain to the defrost condensate pan near compressor and may overflow if not careful. If the timer seems to work then we need to test the defrost heater and defrost thermostat=>
MSD2432GRW Freezer Compartment Components 61006116 Heater and Thermostat Assembly
Instructions are on the lower part of that page on how to test with an OHM meter.
sea_breeze_138.jpg Turn the timer clockwise slowly until the compressor and fans stop. That should manually place the refrigerator into defrost. After a minute or so open the freezer door and listen for crackling or sizzle noise. That will be the sound of defrost. Wait about 30 minutes until timer comes out of defrost itself and if not turn the timer again until compressor and fans start again. If this works out like this then replace the timer. If not then we need to go inside the=> Freezer Compartment Components
Part position 12 is the defrost heater and defrost thermostat. Position 13 is the clip that holds heater in place. 68233-2 Defrost Timer
Should you have questions I will be here to answer, Thanks, Sea Breeze
Apr 14, 2011 | Maytag MSD2432G Side by Side Refrigerator
Refrigerator leaks water underneath and is not cooling good.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 26, 2010 | Maytag Refrigerators
Refrigerators Logo
382 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
